<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.092]]></title><description><![CDATA[<h3>VectorStyler 1.1.092 release notes</h3>
<li>Fixed bug in shape union and merge.</li>
<li>Scaling text could change the font size, also for default font size.</li>
<li>Fixed regression in opacity mask boundary for outlines.</li>
<li>Fixed glyph visibility issues with certain transformation.</li>
<li>Selecting with a box mode in deep select mode should not select both group and member objects.</li>
<li>Do not repeat colors in the color palette when pasting or importing.</li>
<li>Better display refresh when changing between documents.</li>
<li>Aligned stroke with local transform did not render correctly.</li>
<li>Allow Shift+click on Layer panel object selection knob.</li>
<li>Enable spot plate in printing if visibility is enabled.</li>
<li>Fixed refresh issues when editing inside clipped groups.</li>
<li>Adjust the size of the updated image if proportions change.</li>
<li>Pasting an artboard should keep it selected.</li>
<li>Allow multiple color selection in the palette panel.</li>
<li>Fixed object style issues when using object roles.</li>
<li>Better handling of custom toolbox icons.</li>
<li>Allow drag and drop of new color into color palette bar.</li>
<li>Show artboard edges over objects.</li>
<li>General stability improvements.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3266/update-1-1-092</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:50:27 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3266.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Jul 2023 07:45:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.092 on Sat, 08 Jul 2023 15:15:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/19699">update 1.1.092</a>:</p>
<blockquote>
<p dir="auto">Better display refresh when changing between documents.</p>
</blockquote>
<p dir="auto">Thank you - The issue with fixed now on the laptop where I was previously seeing this problem!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19709</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19709</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Sat, 08 Jul 2023 15:15:10 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.092 on Sat, 08 Jul 2023 08:15:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thanks <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
<p dir="auto">A new feature to help with the layout of documents <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19702</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19702</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Sat, 08 Jul 2023 08:15:12 GMT</pubDate></item></channel></rss>
