<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ideas to improve the Vectorstyler Layers Panel]]></title><description><![CDATA[<p dir="auto">I would venture to say that Vectorstyler is unbeatable in<br />
its vector operations capabilities and the apparent ease<br />
with which it is done compared to other programs. On the<br />
other hand, the user experience and user interface design<br />
leaves room for improvement.</p>
<p dir="auto">I would like to highlight the Layers Panel. This important<br />
tool to organize, distribute and manage objects can be<br />
improved. Both in design and functions. There illustrator<br />
is unbeatable with features like:</p>
<li>move object(s) to another layer<br />
(without unfolding and digging into stacks)</li>
<li>paste remembers layers</li>
<li>release groups to layers</li>
<p dir="auto">I have reflected on this and noted my ideas and<br />
recommendations in the following step-by-step approach<br />
with reasoning and examples. Respecting the existing<br />
design as much as possible as a starting point.</p>
<p dir="auto">Viewable in attached PDF<br />
<a href="/forum/assets/uploads/files/1689781978000-vs-layers-panel-ideas-v2.pdf">VS Layers Panel ideas v2.pdf</a></p>
<p dir="auto">Vectorstyler has a very lively open forum where a lot can<br />
be said. The developer responds and communicates well<br />
and has a deep backlog. I feel free to make suggestions<br />
like this completely without obligation. I hope that the<br />
developer and the users and myself of course benefit<br />
from it.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/3294/ideas-to-improve-the-vectorstyler-layers-panel</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 13:06:21 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3294.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Jul 2023 11:26:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Fri, 28 Jul 2023 14:09:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
I don't quite understand.<br />
It's all about moving an object(s) from one layer to another, right?<br />
As long as it is a possibility, that is important. If there is an option to disable the feature and what should be the default? I would say default on, option off.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20078</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20078</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Fri, 28 Jul 2023 14:09:00 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Fri, 28 Jul 2023 13:59:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> said in <a href="/forum/post/20076">Ideas to improve the Vectorstyler Layers Panel</a>:</p>
<blockquote>
<p dir="auto">Clicking on a Layer Name Moves Selected Objects</p>
</blockquote>
<p dir="auto">Would this kind of option be useful?<br />
I think the default can be off.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20077</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20077</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 28 Jul 2023 13:59:27 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Fri, 28 Jul 2023 14:36:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/20075">Ideas to improve the Vectorstyler Layers Panel</a>:</p>
<blockquote>
<p dir="auto">The problem is that the selection knob in this case would just change the selection.<br />
Should there be a modifier key (shift or control) click to have the place into the layer?</p>
</blockquote>
<p dir="auto">I understand that. A modifier key is not much to ask for such a nice feature.<br />
Freehand does something similar, clicking on the targets layers name.*<br />
Illustrator does something similar, by (a special button for this) <strong>dragging</strong> a button to another target button.</p>
<blockquote>
<p dir="auto">Also: do we need "copy into" version where the objects are copied into the layer?</p>
</blockquote>
<p dir="auto">Do not see the use of copying so much. You want to distribute, organize, clean up, make clear, what belongs to what. Creating more objects doesn't fit in this concept.</p>
<p dir="auto">*Note FYI<br />
From the freehand manual</p>
<p dir="auto"><em><strong>To move an object to another layer using the Layers panel:</strong><br />
1 Select the object.<br />
The object’s layer name is highlighted in the Layers panel.<br />
2 In the Layers panel, click the name of the layer to which you will move the selection.<br />
By default, clicking a layer name moves a selected object to that layer.<br />
Note: If this procedure doesn’t work correctly, check your panel preferences. See the following procedure.</em></p>
<p dir="auto"><em><strong>To prevent selected objects from automatically moving to other layers:</strong><br />
1 Display panels preferences by doing one of the following:<br />
• In Windows, press Control+H, then click the Panels tab.<br />
• On the Macintosh, press Command+H, then click the Panels category.<br />
2 Deselect Clicking on a Layer Name Moves Selected Objects, and click OK.</em></p>
]]></description><link>https://www.vectorstyler.com/forum/post/20076</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20076</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Fri, 28 Jul 2023 14:36:38 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Fri, 28 Jul 2023 08:35:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> Question about "<em>Step 5 Create function to move object(s) to another layer</em>":</p>
<p dir="auto">In this feature, after the objects are selected, the user could click on the selection knob to send objects into this location.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20075</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20075</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 28 Jul 2023 08:35:17 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Tue, 25 Jul 2023 09:35:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
If you go towards complying with such requests, so that we clutter the layers panel with things many people will never ever need to consider in their daily work with layers, then I hope you follow your good tradition of making it customizable as preferences.</p>
<p dir="auto">But I strongly recommend that it becomes opt-in because apart from the few experienced users here (and we are hardly representative of many), my experience with people checking out Vectorstyler is that they quickly become overstimulated by the interface, and that's also what I read from reviews. It's a shame if the complexity of the interface people don't like or can't take in is not something they need.</p>
<p dir="auto">And no, people shouldn't have to learn functionality by having it shoved in their face all day. Just to get ahead of the usual Linux-like rhetoric I am met with from time to time (though never from <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a>).</p>
<p dir="auto">Cheers</p>
<p dir="auto"><img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/20002</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20002</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 25 Jul 2023 09:35:57 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Mon, 24 Jul 2023 11:10:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/fde101" aria-label="Profile: fde101">@<bdi>fde101</bdi></a> Got it.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19998</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19998</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Mon, 24 Jul 2023 11:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Mon, 24 Jul 2023 11:05:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> that is what I was answering in my earlier post:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/fde101" aria-label="Profile: fde101">@<bdi>fde101</bdi></a> said in <a href="/forum/post/19912">Ideas to improve the Vectorstyler Layers Panel</a>:</p>
<blockquote>
<p dir="auto">My own take on it: checkmark for visible and printable/exportable, eye for visible but non-printing, printer or paper icon for printing/exporting but not visible in normal edit mode, none for invisible and non-printing.</p>
</blockquote>
]]></description><link>https://www.vectorstyler.com/forum/post/19997</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19997</guid><dc:creator><![CDATA[fde101]]></dc:creator><pubDate>Mon, 24 Jul 2023 11:05:06 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Mon, 24 Jul 2023 10:57:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/fde101" aria-label="Profile: fde101">@<bdi>fde101</bdi></a> I don't disagree that a checkbox/button for 'printable' would be nice — I already wondered<br />
about the guidelines and the grid (I mentioned CDR). <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title="👍" alt="👍" /></p>
<p dir="auto">But I'm not sure a four-way checkbox is best — how should the icons for the first and the last of these four states look?</p>
<li>visible on screen and printer</li>
<li>visible on screen but not printer</li>
<li>visible on printer but not screen</li>
<li>invisible on both screen and printer</li>
]]></description><link>https://www.vectorstyler.com/forum/post/19996</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19996</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Mon, 24 Jul 2023 10:57:27 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Mon, 24 Jul 2023 10:31:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/19914">Ideas to improve the Vectorstyler Layers Panel</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/fde101" aria-label="Profile: fde101">@<bdi>fde101</bdi></a>  I'm not sure a 'printable' button is needed?  Currently if something is<br />
not visible it doesn't get printed or exported.</p>
</blockquote>
<p dir="auto">I'm not suggesting a separate button to waste space on the panel.  I am suggesting a four-way checkbox, which allows for all four possible visibility combinations: visible on screen and printer, visible on screen but not printer, visible on printer but not screen, invisible on both screen and printer.</p>
<p dir="auto">In most cases having these ganged together is fine, but there are special cases where you might want to override that, and moving this to a context menu on the control makes these special cases readily available when they are needed without taking up extra space against the more general usage of the panel.</p>
<p dir="auto">You might want something visible on the screen but not the printer if you are sharing a document with others and want to provide them with instructions on how to finish something but do not want those instructions included in the final output; you may also use this to leave notes for yourself that are only available in the editing view.</p>
<p dir="auto">A bit more rare of a special case, but one example of when you might want something to print but not be visible on the screen would be if you have some kind of framing that is distracting or making selection harder while working on the core part of the document, but which you don't want to forget to include when printing it - you could add simple guides to keep your place then mark the framing as print only, using the guides to keep the content aligned, and to see the end result would simply do a print or print preview.  While in many cases you could also accomplish this by grouping the framing and toggling the global visibility, if you have a complex layering structure and parts of the framing are both above and below the core content, this avoids scrolling the layers panel; it also hides the guides you are working with (when performing a print preview), allowing you to do everything in one step.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19993</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19993</guid><dc:creator><![CDATA[fde101]]></dc:creator><pubDate>Mon, 24 Jul 2023 10:31:41 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 22:20:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> Let's not go off-topic and mess up Ayo's thread.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19974</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19974</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sat, 22 Jul 2023 22:20:43 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 21:46:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> joking aside there's some real potential there</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19973</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19973</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Sat, 22 Jul 2023 21:46:12 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 21:39:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> Ayo made a joke, I also made one — that's it, nothing more.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19972</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19972</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sat, 22 Jul 2023 21:39:51 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 22:26:22 GMT]]></title><description><![CDATA[<p dir="auto">No offense  <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> , I do like the streamlined look of the one <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> whipped up. It would be cool with some special effects and the cursor cross icon in there</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19971</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19971</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Sat, 22 Jul 2023 22:26:22 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 21:24:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> Absolutely!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19970</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19970</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sat, 22 Jul 2023 21:24:03 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 21:17:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> Don't take it too seriously. Was just a design joke. We are all in the first place designers, aren't we?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19969</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19969</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Sat, 22 Jul 2023 21:17:52 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sun, 23 Jul 2023 21:10:17 GMT]]></title><description><![CDATA[<p dir="auto">All right… in all seriousness, I have to acknowledge that there are indeed<br />
vector-based apps that use a checkmark for layer and object visibility<br />
(and export) instead of an eye. Some because the functionality of their Layers<br />
panel is simple, some other despite the complexity (Affinity, I guess).</p>
<p dir="auto">To me a checkmark still seems too generic (it doesn't scream 'visibility').<br />
Besides that, there are other places in the app where the concept of 'visibility'<br />
is used (Hidden object, Show All Objects, New View, Select All Inside View),<br />
and I don't think using a checkmark in the icons of these commands would work.</p>
<p dir="auto">(I'm trying to make icons for these commands as well, so we could continue<br />
the discussion when I post them on the forum. The icons won't be perfect,<br />
I'm sure).</p>
<p dir="auto">OK, said enough about this, I rest my case.  <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title="🙂" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19968</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19968</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sun, 23 Jul 2023 21:10:17 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 20:37:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> I beg to differ, the eye is staring you in the face. <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title="🙂" alt="🙂" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1690056839784-s.png" alt="0_1690056838087_s.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">……<br />
…<br />
.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19967</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19967</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sat, 22 Jul 2023 20:37:26 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 19:56:22 GMT]]></title><description><![CDATA[<p dir="auto">a final argument for the checkmark : )</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1690055578212-83246dd4-d928-43e2-bba6-b3052ceeffa0-image.png" alt="0_1690055575133_83246dd4-d928-43e2-bba6-b3052ceeffa0-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19966</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19966</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Sat, 22 Jul 2023 19:56:22 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Sat, 22 Jul 2023 17:52:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/19895">Ideas to improve the Vectorstyler Layers Panel</a>:</p>
<blockquote>
<p dir="auto">Are there other graphics apps using a validation sign in the Layers panel?</p>
</blockquote>
<p dir="auto">Came across this.<br />
Nice variation. Layers panel –I suppose– on the left hand side this time. On/off (with checkmarks) on the panels right side, close to the users working center.</p>
<p dir="auto">From earlier post today: Toucan<br />
Home/General Discussion/The first vector graphics editor built for generative design</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1690047790765-75d70415-19d1-40a7-bb4f-36c364a8ccb5-image.png" alt="0_1690047764425_75d70415-19d1-40a7-bb4f-36c364a8ccb5-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19965</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19965</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Sat, 22 Jul 2023 17:52:27 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Thu, 20 Jul 2023 23:32:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/fde101" aria-label="Profile: fde101">@<bdi>fde101</bdi></a>  I'm not sure a 'printable' button is needed?  Currently if something is<br />
<p dir="auto">Except for the grid and guidelines. Hmm… <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f914.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--thinking_face" style="height:23px;width:auto;vertical-align:middle" title="🤔" alt="🤔" /></p>
<p dir="auto">In any case, I would say that…</p>
<p dir="auto">'Printable' → small printer button → no reading of the manual needed.</p>
<p dir="auto">CDR has it like that — a 'printer' button for objects, guidelines and for the grid in its<br />
Layers panel (named 'Object Manager'), along the 'eye' and 'lock' buttons.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19914</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19914</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Thu, 20 Jul 2023 23:32:18 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Thu, 20 Jul 2023 22:15:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/19900">Ideas to improve the Vectorstyler Layers Panel</a>:</p>
<blockquote>
<p dir="auto">Well, I personally still like the filled eye better.</p>
</blockquote>
<p dir="auto">Normal left click toggles between none and whatever it was set to of the three other options.  Right click opens context menu to pick from all four options.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19912</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19912</guid><dc:creator><![CDATA[fde101]]></dc:creator><pubDate>Thu, 20 Jul 2023 22:15:56 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Thu, 20 Jul 2023 12:27:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/19908">Ideas to improve the Vectorstyler Layers Panel</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a>  If possible, can you include two screenshots with v1 and v2 of AD's Layers panel?<br />
I searched them a bit but I'm not sure those I found are not from AD's Pixel "Persona",<br />
which might look different (I guess).</p>
</blockquote>
<p dir="auto">Version 2:<br />
<img src="/forum/assets/uploads/files/1689855466170-d860f5f9-c2e8-4f07-ab8a-eab33b8a382d-image.png" alt="0_1689855465335_d860f5f9-c2e8-4f07-ab8a-eab33b8a382d-image.png" class=" img-fluid img-markdown" /><br />
<img src="/forum/assets/uploads/files/1689855501248-637d29b3-a846-4c82-a8cb-92a344809189-image.png" alt="0_1689855500935_637d29b3-a846-4c82-a8cb-92a344809189-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Pure crap UI:<br />
<img src="/forum/assets/uploads/files/1689855536859-1f5b3bd5-ebdc-4c38-afdb-60c2e7cb7cac-image.png" alt="0_1689855536723_1f5b3bd5-ebdc-4c38-afdb-60c2e7cb7cac-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Compared to the absolute calm and no nonsense interface in version 1 I NEVER had trouble using or navigating in. Everything from this point and 'up' should be opt-in.<br />
<img src="/forum/assets/uploads/files/1689856039142-ceeb4a76-5cdc-4704-9ad7-f8e95a69de8e-image.png" alt="0_1689856038838_ceeb4a76-5cdc-4704-9ad7-f8e95a69de8e-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19911</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19911</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Thu, 20 Jul 2023 12:27:20 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Thu, 20 Jul 2023 11:59:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> Not clear if you did work in an app that has this alternative mode and didn't like it,<br />
but all right…</p>
<p dir="auto">I'm asking because auto-locking of layers makes both restricted selecting of objects<br />
and jumping to another layer much easier and faster, since you don't need to walk<br />
the mouse all the way to the Layers panel, and locking other objects  to avoid selecting<br />
them becomes unnecessary most of the time.</p>
<p dir="auto">So in this case at least these buttons can be left on the right side of the Layers panel.</p>
<p dir="auto">(I'm not advising for this mode to be enabled by default, but… with big monitors these<br />
days I think it would help a lot).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19910</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19910</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Thu, 20 Jul 2023 11:59:17 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas to improve the Vectorstyler Layers Panel on Thu, 20 Jul 2023 11:47:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/19908">Ideas to improve the Vectorstyler Layers Panel</a>:</p>
<blockquote>
<p dir="auto">Auto-lock' for inactive layers</p>
</blockquote>
<p dir="auto">I'm not that fond of 'Auto' or self-thinking functions</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19909</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19909</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Thu, 20 Jul 2023 11:47:17 GMT</pubDate></item></channel></rss>
