<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.093]]></title><description><![CDATA[<h3>VectorStyler 1.1.093 release notes</h3>
<li>Fixed 16 bit display mode error.</li>
<li>Allow corner shapes from groups with the corner shape role.</li>
<li>Editing stroke options from the Contour panel should select the stroke.</li>
<li>Correct shape boundary when applying effects on text objects with stroke outline.</li>
<li>Update list of icons on changes, in the icon selector.</li>
<li>Flipping selected nodes around the current pivot.</li>
<li>Allow selecting duplicate colors in the color palette panel.</li>
<li>Select inside composite shapes by outline.</li>
<li>Correct font size for shape text after scaling.</li>
<li>Noise generator effects in CMYK mode should not create noise for the K component.</li>
<li>Undo and redo after moving an artboard with its content.</li>
<li>Correct alignment of blur extent mask.</li>
<li>Stroke width panel content to update correctly after changes.</li>
<li>Fixed kerning issue with OpenType fonts containing repeated kerning data.</li>
<li>Better scrolling in integer fields.</li>
<li>Blending steps in smooth mode should also consider gradient colors.</li>
<li>Node coordinates in transform panel should not include control point in the bounding box.</li>
<li>Exporting strokes with uneven caps into SVG files.</li>
<li>Export thin stroke correctly into SVG file.</li>
<li>Fixed crash when undoing certain appearance changes.</li>
<li>Style picker tool to select from inside symbols also.</li>
<li>Shape text fill and stroke order to be kept when converting to frame text.</li>
<li>Simplify Path command to work on selected nodes also.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3295/update-1-1-093</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:50:26 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3295.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Jul 2023 06:34:25 GMT</pubDate><ttl>60</ttl></channel></rss>
