<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.095]]></title><description><![CDATA[<h3>VectorStyler 1.1.095 release notes</h3>
<li>Shape paint tool to work with cloned objects also.</li>
<li>Do not move shapes when converting the sources of a clone to curves.</li>
<li>Changing artboard position in modal view to move artboard guidelines also.</li>
<li>Artboard option to always edit current artboard.</li>
<li>Better curve location points in node editor.</li>
<li>Use correct units when editing artboard grid options.</li>
<li>Control+click context menu on selected objects should not change selection.</li>
<li>Update blend panel content when the blend object is inside a selected group.</li>
<li>Drag and drop artboard in canvas panel should copy locked content also.</li>
<li>Better glyph recovery when importing PDF files.</li>
<li>Snapping to grid should work when snap to guideline is enabled.</li>
<li>Update label in shape style drop down.</li>
<li>Clip to canvas size and correct default canvas options.</li>
<li>Changing the large canvas mode option should reset the document view zoom.</li>
<li>Fixed regression in shape builder when trying to remove parts of shapes.</li>
<li>Correct icon size options in preset and styles panel.</li>
<li>Adjusting color values with arrow keys should not fall back to nudging.</li>
<li>Fixed action panel folder rearrangement.</li>
<li>Anchor tool should not use path extension location.</li>
<li>Block modal views in recorded action playback.</li>
<li>Display shortcut name for quote key.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3340/update-1-1-095</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:50:22 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3340.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Jul 2023 16:27:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.095 on Mon, 31 Jul 2023 19:52:01 GMT]]></title><description><![CDATA[<p dir="auto">Wow, thanks for making fixes so fast!!!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20154</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20154</guid><dc:creator><![CDATA[pentool]]></dc:creator><pubDate>Mon, 31 Jul 2023 19:52:01 GMT</pubDate></item></channel></rss>
