<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.018 RC1]]></title><description><![CDATA[<h3>VectorStyler 1.0.018 RC1 release notes</h3>
<li>Improved: show imported image and linked file info when hovering over the file name in the <em>Content Links</em> panel.</li>
<li>Improved: allow separate mask source for <em>Inner/Outer Glow</em> filter.</li>
<li>Improved: add color toning option for tiling patterns, and style override for pattern content.</li>
<li>Fixed: support of multiple screens on both Mac and Windows.</li>
<li>Fixed: tool tips on Windows did not work.</li>
<li>Fixed: display refresh did not always work in OpenGL display mode.</li>
<li>Fixed: avoid moving objects or nodes when only clicking.</li>
<li>Fixed: multi key shortcuts were not correctly handled on Windows.</li>
<li>Fixed: canceling  shape effect view opened from layers (or appearance) panel broke the effects.</li>
<li>Fixed: smaller snapping indicator for point and shape snapping modes.</li>
<li>Fixed: option for common global snapping modes (Preferences -&gt; Editing Options -&gt; Common Snapping Options). By default each document stores its own snapping settings.</li>
<li>Fixed: cursor in Windows did not restore when moving back into view.</li>
<li>Fixed: paste in place for path copied into clipboard should keep original position.</li>
<li>Fixed: removing nodes from a shape converted some nodes to cusp.</li>
<li>Fixed: importing transformed gradients in SVG did not position correctly.</li>
<li>Fixed: extending and redrawing path with the pencil tool.</li>
<li>Fixed: palette opening button resulted in empty menu on Windows. Should open file selection if there are no scanned palettes.</li>
<li>Fixed: jitter in expander brush preview.</li>
<li>Fixed: reduce cross mark for eraser and expander brushes.</li>
<li>Fixed: changing stroke cap should not change other attributes.</li>
<li>Fixed: changing preserve color option did not detach image effect instance.</li>
<li>Fixed: thinner dash preview in stroke panel with more phases.</li>
<li>Fixed: remove save and export icons from the tool bar.</li>
<li>Fixed: panel snapping to be less intrusive.</li>
<li>Fixed: check for updates on Windows did not correctly identify version.</li>
<li>Fixed: did not undo <em>rotate with frame</em> option of text frames.</li>
<li>Fixed: searching in customize view.</li>
<li>Fixed: color panel layout breaks at small sizes.</li>
<li>Fixed: clearing fill from color palette (panel and bar) did not work.</li>
<li>Fixed: increase and decrease brush size in the brush tool did not work on Windows.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/342/update-1-0-018-rc1</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:13 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/342.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Mar 2021 19:40:49 GMT</pubDate><ttl>60</ttl></channel></rss>
