<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.100]]></title><description><![CDATA[<h3>VectorStyler 1.1.100 release notes</h3>
<li>Keep action command folders open when docking panels.</li>
<li>New shape may should end up in the current layer.</li>
<li>Minimized panels should not jump when moved.</li>
<li>Fixed regression in snapping to reference sizes.</li>
<li>Show an alert view on the Revert command.</li>
<li>Option to show a smaller layer and object drag preview in layers panel.</li>
<li>Snapping angles editing to start with no selection.</li>
<li>Initial transform pivot mode for flip commands.</li>
<li>Change position for the snapping panel button in the tool bar.</li>
<li>Option to flatten all curves to lines when printing with printer drivers.</li>
<li>Keep a minimum size when resizing docked panels.</li>
<li>Fixed regression in Haze effect rendering.</li>
<li>Deleting in action panel to select previous item.</li>
<li>Show composited groups with a special label in the layers panel.</li>
<li>Also move, rotate and scale artboard content when changes are made in modal view.</li>
<li>Canvas roles selected in modal view were not applied.</li>
<li>Improved precision of collision snapping for small curves.</li>
<li>Exclude group of shapes from an other shape.</li>
<li>Do not create group content for a shape when isolated, only when. new object is created inside.</li>
<li>Erasing from clipping group shapes to skip path separation.</li>
<li>Also modify locked objects inside groups when expanding or converting to curves.</li>
<li>Improved color slider updating on color mode change.</li>
<li>Change selected shape after using the path brush tool.</li>
<li>Deleting an action while recording should stop the recording.</li>
<li>Fixed regression in selecting shape corners in the modal shape view.</li>
<li>Outline preview to render outlines correctly at larger zoom levels.</li>
<li>Fixed regressions in editing with repeater modal view.</li>
<li>Correct bounding box when rasterizing vector brush objects.</li>
<li>Keep transparency when rasterizing objects.</li>
<li>Better detection of AI file content in imported EPS files.</li>
<li>Disabled calibration mode by default for document preview on Windows (turn it on in preferences).</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3442/update-1-1-100</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:50:24 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3442.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Aug 2023 18:56:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.100 on Fri, 18 Aug 2023 17:29:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> Only on Windows for now, in the Graphics tab of the Printer view</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20726</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20726</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 18 Aug 2023 17:29:00 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.100 on Fri, 18 Aug 2023 17:23:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/20605">update 1.1.100</a>:</p>
<blockquote>
<p dir="auto">Option to flatten all curves to lines when printing with printer drivers.</p>
</blockquote>
<p dir="auto">Where is this option located specifically?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20725</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20725</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Fri, 18 Aug 2023 17:23:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.100 on Mon, 14 Aug 2023 19:25:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/20605">update 1.1.100</a>:</p>
<blockquote>
<p dir="auto">Change position for the snapping panel button in the tool bar.</p>
</blockquote>
<p dir="auto">This is perfect! I know this issue was affecting only me currently, but it solves the problem for anyone with a two screen setup where they digitally are side by side.</p>
<p dir="auto">Taking a screenshot of the solution actually captured a portion of the other screen as well so that confirms to me that was the issue prior.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1692041122527-d0588a7f-feb6-4a06-8611-a1b114dfcff9-bld-2023-08-14-at-15.21.48-2x.png" alt="0_1692041111172_d0588a7f-feb6-4a06-8611-a1b114dfcff9-BLD 2023-08-14 at 15.21.48@2x.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/20606</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20606</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 14 Aug 2023 19:25:41 GMT</pubDate></item></channel></rss>
