<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.101]]></title><description><![CDATA[<h3>VectorStyler 1.1.101 release notes</h3>
<li>Access and manage display presets in the preset manager.</li>
<li>Fixed document tab closing issue with multiple open documents.</li>
<li>Fixed exporting images into SVG.</li>
<li>Setting uniform scaled stroke width on multiple objects should result on the same apparent width.</li>
<li>Do not select multiple palette colors when dragging the mouse in the palette grid.</li>
<li>Wrong selection after assigning a blend path to the blend object.</li>
<li>Grouping objects from layers containing position offset.</li>
<li>Setting the selected color of a gradient using the color sliders.</li>
<li>Confirming gradient from the modal editor when opend from a fill popup should apply the changes on the selection.</li>
<li>Changing reference canvas roles multiple times should update style lists.</li>
<li>Update current color in palette panel, even if not visible.</li>
<li>Do not snap reference point to grid.</li>
<li>Do not use Shift modifier when working the color sliders.</li>
<li>Pen tool should constrain lines with Shift also after modifying a node.</li>
<li>Correctly enable or disable the Edit Color command of the palette menu, depending on the selection status.</li>
<li>Fixed rendering adjustment effects on text shapes with multiple styles.</li>
<li>Allow using the Shift modifier while editing the opacity in the Appearance panel.</li>
<li>Select color mode when changing colors inside an isolated mask.</li>
<li>Fixed crash when ungrouping inside an isolated mask.</li>
<li>Allow dragging AI format onto a VectorStyler document.</li>
<li>Fixed text scaling issues of text on path inside a group.</li>
<li>Positioning the last object for of a blend aligned to a path.</li>
<li>Fixed crash when changing blend object order in the Layers panel.</li>
<li>Changed how numbers are edited in the various snapping list views.</li>
<li>Select small text shape using the bounding box of the glyphs.</li>
<li>General stability improvements.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3483/update-1-1-101</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:50:24 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3483.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Aug 2023 12:03:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.101 on Sun, 27 Aug 2023 22:12:21 GMT]]></title><description><![CDATA[<p dir="auto">Yes, snapping panel looks good.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20834</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20834</guid><dc:creator><![CDATA[pentool]]></dc:creator><pubDate>Sun, 27 Aug 2023 22:12:21 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.101 on Sun, 27 Aug 2023 20:36:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Here it was fixed after resetting the app by holding down Command-Shift-Option on start.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20833</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20833</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sun, 27 Aug 2023 20:36:24 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.101 on Sun, 27 Aug 2023 20:11:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/pentool" aria-label="Profile: pentool">@<bdi>pentool</bdi></a> And I see that in the background the Snapping panel has wrong resources.<br />
Was this fixed after clearing out the user data?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20832</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20832</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 27 Aug 2023 20:11:17 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.101 on Sun, 27 Aug 2023 18:17:28 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I had that happen.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1693160245587-screen-shot-2023-08-27-at-7.01.36-pm-resized.png" alt="0_1693160245003_Screen Shot 2023-08-27 at 7.01.36 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/20831</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20831</guid><dc:creator><![CDATA[pentool]]></dc:creator><pubDate>Sun, 27 Aug 2023 18:17:28 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.101 on Sun, 27 Aug 2023 18:04:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/pentool" aria-label="Profile: pentool">@<bdi>pentool</bdi></a> There is a new "diagnostic" phase at startup, for the case where old resources hang around for some reason.</p>
<p dir="auto">So if you get a notification after VS starts, just remove the user data and then things should work.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20829</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20829</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 27 Aug 2023 18:04:58 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.101 on Sun, 27 Aug 2023 17:00:36 GMT]]></title><description><![CDATA[<p dir="auto">Seems like a lot has been fixed. Thank you! Let's keeps fingers crossed.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20826</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20826</guid><dc:creator><![CDATA[pentool]]></dc:creator><pubDate>Sun, 27 Aug 2023 17:00:36 GMT</pubDate></item></channel></rss>
