<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.102]]></title><description><![CDATA[<h3>VectorStyler 1.1.102 release notes</h3>
<li>Fixed regression in syncing global colors.</li>
<li>Panel vertical resizing cursor was not shown.</li>
<li>Remove inactive zone when trying to drag panels from the title area.</li>
<li>Correct removing both starting and ending nodes of an open path at the same time.</li>
<li>Fixed regression in Appearance panel color updating.</li>
<li>Fixed regression in working with popovers from Appearance panel.</li>
<li>Fixed opacity slider in context panel for mesh gradient editing.</li>
<li>Fixed crash when using Break Apart on text.</li>
<li>Transform pivot should be relative to arc or pie center point.</li>
<li>Default spine path of rotated blend should transform correctly.</li>
<li>Displayed dashes with zero length dots at the path endings.</li>
<li>Restart notification of certain preference changes.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3503/update-1-1-102</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:50:28 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3503.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Sep 2023 06:52:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.102 on Sun, 03 Sep 2023 17:29:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Yes, I confirm. The problem has been fixed.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20951</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20951</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Sun, 03 Sep 2023 17:29:33 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.102 on Sun, 03 Sep 2023 11:04:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> Correction uploaded in a new build.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20943</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20943</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 03 Sep 2023 11:04:34 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.102 on Sat, 02 Sep 2023 07:44:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> I will reopen this issue.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20928</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20928</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 02 Sep 2023 07:44:55 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.102 on Sat, 02 Sep 2023 07:41:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/20926">update 1.1.102</a>:</p>
<blockquote>
<p dir="auto">Fixed crash when using Break Apart on text.</p>
</blockquote>
<p dir="auto">In my case, the problem is still present</p>
]]></description><link>https://www.vectorstyler.com/forum/post/20927</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/20927</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Sat, 02 Sep 2023 07:41:54 GMT</pubDate></item></channel></rss>
