<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.019 RC1]]></title><description><![CDATA[<h3>VectorStyler 1.0.019 RC1 release notes</h3>
<li>Fixed: exporting adjustment layers with distortion effects.</li>
<li>Fixed: color separation did not work in printing.</li>
<li>Fixed: hidden color plates should not be printed.</li>
<li>Fixed: some process colors were added as spot plates in color separation.</li>
<li>Fixed: crash when importing certain EPS files.</li>
<li>Fixed: problems when exporting EPS files with adjustment layers.</li>
<li>Fixed: detect and load spot colors in PDF and AI import.</li>
<li>Fixed: detect color mode when opening AI files.</li>
<li>Fixed: font metric based kerning did not work for some OpenType fonts.</li>
<li>Fixed: inserting glyphs at cursor position from Glyphs panel did not work.</li>
<li>Fixed: add stylistic set access to Typography panel.</li>
<li>Fixed: jumping scroll position in History panel, as undo and redo is browsed.</li>
<li>Fixed: color of the outline indicator in Pen tool should match the layer color.</li>
<li>Fixed: various stability improvements.</li>
<li>Fixed: various UI style improvements.</li>
<li>Fixed: problems when editing artboard guidelines in the modal view.</li>
<li>Fixed: undo in path brush tool when new objects are created.</li>
<li>Fixed: load per image color profiles, and show the profile name in the content links panel.</li>
<li>Fixed: swapping color target with X shows the wrong colors.</li>
<li>Fixed: erasing a path from a composite shape should not remove the whole object.</li>
<li>Fixed: issues with knife tool on composite shapes.</li>
<li>Fixed: select all touched objects in eraser tool for changes when starting with no selection.</li>
<li>Fixed: if eraser (or path brush) tool is opened with a selection, all changes are made on the selected objects only.</li>
<li>Fixed: eraser tool may break undo and redo history.</li>
<li>Fixed: smaller label for brush size change indicator.</li>
<li>Fixed: remove OpenGL display mode on M1.</li>
<li>Fixed: add pattern content tint options to modal view also.</li>
<li>Fixed: set pattern tile outline and background in modal view also.</li>
<li>Fixed: default pattern content label should be <em>Default</em>.</li>
<li>Fixed: create unique new preset (or style) name when creating presets(or styles).</li>
<li>Fixed: warn if preset creation overwrites an existing name.</li>
<li>Fixed: do not allow confirm in preset creation of name is empty.</li>
<li>Fixed: single key shortcuts on Windows were not found when pressing the key in the shortcut editor.</li>
<li>Fixed: use thinner hovering outline.</li>
<li>Fixed: zero dash did not use cap shapes properly.</li>
<li>Fixed: dash starting with zero did not render correctly on closed shapes.</li>
<li>Fixed: ungrouping clipped groups with style should not copy the style to the objects.</li>
<li>Fixed: extent of imported SVG gradient was wrong.</li>
<li>Fixed: allow extra space around transform box for movement also.</li>
<li>Fixed: opacity and transparency options were not correctly identified in selecting by similarity.</li>
<li>Fixed: slider layout in shadows and highlights filter.</li>
<li>Fixed: enable scrubby scrolling in number editor fields and labels.</li>
<li>Fixed: gradient tool to adjust nodes to object size.</li>
<li>Fixed: some installed TTF fonts are not detected correctly.</li>
<li>Fixed: improved slider mapping in character panel.</li>
<li>Fixed: scrolling artboard number in print preview did not work.</li>
<li>Fixed: better layout for panel titles.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/363/update-1-0-019-rc1</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:19 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/363.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Mar 2021 21:39:22 GMT</pubDate><ttl>60</ttl></channel></rss>
