<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.112]]></title><description><![CDATA[<h3>VectorStyler 1.1.112 release notes</h3>
<li>General stability improvements.</li>
<li>Fixed knife tool regression with composite shapes.</li>
<li>Better brush width indicator for eraser and path brush tools.</li>
<li>Reversing the path while in the Pen tool: create correct extension control points.</li>
<li>Delete nodes in the stroke profile view with backspace.</li>
<li>Allow layer selection when releasing groups to layers.</li>
<li>Fixed bug when creating selection presets from expanded repeater objects.</li>
<li>Improved Guidelines panel and under / redo handling of guideline changes.</li>
<li>Artboard label alignment to correctly position labels.</li>
<li>Nudging with larger or smaller amounts to use correct units.</li>
<li>Fixed a bug that caused the Pen tool to get blocked.</li>
<li>Converting shape text aligned on a path, with a symbol inside should position the symbol correctly.</li>
<li>Alignment on shape tool to position objects with offset correctly.</li>
<li>Allow longer path for shape text baseline to avoid overlow.</li>
<li>Improved find / replace for objects.</li>
<li>Contour effect to work with no fill or hidden source object.</li>
<li>Do not show indicators for invisible objects.</li>
<li>Unpluging a second monitor on Windows should reposition panels.</li>
<li>Improved bend effect for crossing bend shape.</li>
<li>Changed the default font for shape text.</li>
<li>Node selection in transform mode to show the bounding box of nodes only.</li>
<li>Aligning blend objects should not change the relative position of the blend.</li>
<li>Allow inversion of smooth corners.</li>
<li>Fixed a regression breaking the text frame when changing a font or other character attributes over the whole frame.</li>
<li>Drag and drop preview option of the Layers panel to activate after changing.</li>
<li>Text tool to start the selection of text correctly in unselected text also.</li>
<li>Add extrema points to the shape when using it as an envelope shape.</li>
<li>Image scaling to correctly handle margin pixels.</li>
<li>Remove document name from window title when closing.</li>
<li>Undo / redo to work after changing the blend mode of the fill style.</li>
<li>Undoing the artboard rotation to keep the artboard selected.</li>
<li>Changed the meter shorthand to mt.</li>
<li>Paste Shape to be grayed out when no object is selected.</li>
<li>Better contrast for the Layers panel drag and drop indicator.</li>
<li>Expanding stroke of cloned objects to be handled correctly.</li>
<li>Allow zero sized repeater items (as invisible objects).</li>
<li>Correct preview of text frame settings when changing both column and inset values.</li>
<li>Select all in the node tool should work the same way as using the box selection.</li>
<li>Path closing change to work on objects inside groups also.</li>
<li>Deselecting nodes in the Node tool should deselect objects also if no nodes are selected.</li>
<li>Fixed color deletion bug in list mode of the color palette.</li>
<li>Select all Members in the Layers panel should not open the groups.</li>
<li>Ungroup to keep layers and ungroup layer content only.</li>
<li>Appending actions in the Action panel should also work if no actions are defined.</li>
<li>Reset tool tips when shortcuts are changed.</li>
<li>Improved sensitivity of docking panels at at the bottom of right-docked panels.</li>
<li>Convert Text menu to show correct name based on selection.</li>
<li>Refresh document when object styles are updated.</li>
<li>Clicking into an empty line inside a text frame should position the cursor correctly.</li>
<li>Improved shape paint tool, to handle global fill selection.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3690/update-1-1-112</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:50:25 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3690.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Nov 2023 09:44:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.112 on Sat, 04 Nov 2023 13:20:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/li-xiao" aria-label="Profile: Li-Xiao">@<bdi>Li-Xiao</bdi></a> said in <a href="/forum/post/22031">update 1.1.112</a>:</p>
<blockquote>
<p dir="auto"><a href="http://vectorstyler.com/buildv1_1_112/vectorstyler.msi" rel="nofollow ugc">http://vectorstyler.com/buildv1_1_112/vectorstyler.msi</a>  404 Not Found</p>
</blockquote>
<p dir="auto">Fixed.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/22035</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/22035</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 04 Nov 2023 13:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.112 on Sat, 04 Nov 2023 11:53:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
]]></description><link>https://www.vectorstyler.com/forum/post/22031</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/22031</guid><dc:creator><![CDATA[Li Xiao]]></dc:creator><pubDate>Sat, 04 Nov 2023 11:53:53 GMT</pubDate></item></channel></rss>
