<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.114]]></title><description><![CDATA[<h3>VectorStyler 1.1.114 release notes</h3>
<li>General stability improvements.</li>
<li>Fixed bug in duplicating multiple text frames.</li>
<li>Expanding bristle brush on certain curves.</li>
<li>Fixed bug in bristle using width profiles.</li>
<li>Improved path offsetting and stroke profile handling.</li>
<li>Fixed bug in outline zigzag effect on complex shapes.</li>
<li>Blending and contour of stroke cap shapes.</li>
<li>Artboard label settings to be used on artboards.</li>
<li>Added a preview button to the create guidelines view.</li>
<li>Text baseline path should not extend beyond text.</li>
<li>Better tracking handling with text on path.</li>
<li>Creating text on path with selected shape to position the path correctly.</li>
<li>Show correct font when a new paragraph text is selected.</li>
<li>Updating selection presets to capture selection correctly.</li>
<li>Number fields in text formatting options to use the font size units.</li>
<li>Selecting text should work between multiple linked frames.</li>
<li>Do not add extra leading before the first line.</li>
<li>Fixed bug when exporting to PDF with certain fonts (SF Pro).</li>
<li>Fixed a bug in adding large corner to rectangles.</li>
<li>Fixed a bug when rearranging artboards in the canvas panel.</li>
<li>Allow corner shape preset and style creation from composite and closed shapes also.</li>
<li>Show outline while hovering with the node tool for parametric shapes also.</li>
<li>Show text cursor when creating an empty text frame.</li>
<li>Document save indicator to update when opening a document.</li>
<li>Fixed a bug with the select shape and link shape commands.</li>
<li>Fixed a regression in using host system hyphenation options.</li>
<li>Hyphenated works should highlight correctly.</li>
<li>Allow exit from isolated mode with the node tool also.</li>
<li>Deleting nodes around straight lines should keep lines straight.</li>
<li>Fixed a possible crash when using style and symbols links.</li>
<li>Keep the correct position when creating reference form an object.</li>
<li>Do not change symbols with color filters (requires expansion first).</li>
<li>Fixed a bug with the small caps (and petite caps feature.</li>
<li>Allow width profile node deletion in the modal view also.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3767/update-1-1-114</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:40:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3767.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Nov 2023 20:45:06 GMT</pubDate><ttl>60</ttl></channel></rss>
