<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.020 of RC1]]></title><description><![CDATA[<h3>VectorStyler 1.0.020 RC1 release notes</h3>
<li>Improved: overprint support for object styles and spot colors.</li>
<li>Improved: support for MacOS based hyphenation.</li>
<li>Improved: change font size and scaling factor when resizing text.</li>
<li>Improved: option for proportional text, image and linked content scaling.</li>
<li>Improved: hold <em>Option</em> when scaling text frame to scale font also.</li>
<li>Improved: hold <em>Shift</em> when clicking on a color to change text color inside text frame (instead of the frame fill).</li>
<li>Improved: grid shape tool to allow odd number of columns.</li>
<li>Improved: adjust blend position with a separate transfer function.</li>
<li>Improved: show text content as default object name in then layers panel.</li>
<li>Fixed: copy and paste text frame did not detach text content.</li>
<li>Fixed: OpenType based kerning bugs.</li>
<li>Fixed: do not truncate font name in font list.</li>
<li>Fixed: ordering in font style menu.</li>
<li>Fixed: undo fill style change of text frame.</li>
<li>Fixed: elastic warp should add nodes from then first click.</li>
<li>Fixed: some spot colors did not import correctly from PDf and AI files.</li>
<li>Fixed: exporting fonts to PDF and PS files.</li>
<li>Fixed: text shape highlight outline path is not updated.</li>
<li>Fixed: various scrubby scrolling issues.</li>
<li>Fixed: handling the enter key in text shape and frame editing on Windows.</li>
<li>Fixed: setting the layer color on Windows closed the view after the first click.</li>
<li>Fixed: delayed menu opening on Windows.</li>
<li>Fixed: corner editor jumps for some shapes.</li>
<li>Fixed: default tab spacing should use the fixed space.</li>
<li>Fixed: deleting a node changed a neighboring corner type.</li>
<li>Fixed: duplicating artboard did not correctly duplicate blend object.</li>
<li>Fixed: selection in numeric field did not always work.</li>
<li>Fixed: use Shift+ to speed up scrubby scrolling.</li>
<li>Fixed: cannot scale at small zoom.</li>
<li>Fixed: text frame knob is tool close to corner.</li>
<li>Fixed: new document should use last created document artboard size.</li>
<li>Fixed: keep last brush used in the brush tool, if it was a stroke preset also.</li>
<li>Fixed: use geometric order by default in alignment panel.</li>
<li>Fixed: show override font of selected text shape.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/379/update-1-0-020-of-rc1</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:17 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/379.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Mar 2021 09:26:34 GMT</pubDate><ttl>60</ttl></channel></rss>
