<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.115]]></title><description><![CDATA[<h3>VectorStyler 1.1.115 release notes</h3>
<li>General stability improvements.</li>
<li>Improved MacOS Sonoma compatibility.</li>
<li>Fixed a bug with the knife tool on complex shapes.</li>
<li>Fixed a bug in SVG and PDF text importing.</li>
<li>Fixed a regression in repeater.</li>
<li>Changing object size inside flipped group should use the correct pivot point.</li>
<li>Exclude in composite shape to be the same as the exclude operation.</li>
<li>Paste appearance to an object with existing object style.</li>
<li>Switching to gray-scale sliders should select a gray color.</li>
<li>Scaling text containing a local baseline path.</li>
<li>Improved paragraph style handling.</li>
<li>Show all available backup files when opening the app.</li>
<li>Allow scrolling of numbers in color fields.</li>
<li>Show the outline of a text frame when using the Node tool.</li>
<li>Added a preview option in shape view.</li>
<li>Path editing in outline mode to preview the moved path.</li>
<li>Expand symbols command to work inside groups also.</li>
<li>Improved symbol spray and adjustment tools.</li>
<li>Rasterize to use correct object size when distortion image effects are used.</li>
<li>Option to preview vector brush settings from modal view.</li>
<li>Better handling of images as masks inside vector brushes.</li>
<li>Improved brush tip preview in eraser and path brush tools.</li>
<li>Contour options to allow color mode selection.</li>
<li>Select tool tip delay option without restarting the app.</li>
<li>Better handing of snapping in shape drawing tools.</li>
<li>Allow monochrome icons when customizing icons.</li>
<li>Update color panel when color style of selected object changes.</li>
<li>Fixed a bug in text frame option selection.</li>
<li>Additional transform panel options for selecting stroke and effect transformation modes.</li>
<li>Use the guideline options selected in artboard format of document setup.</li>
<li>Better handling of blend objects inside tiling patterns.</li>
<li>Set the length of a side for a polygon shape.</li>
<li>Scatter brush to use the width profile for symbol scaling.</li>
<li>Transform angle selection from the horizontal transform panel.</li>
<li>Copy and paste objects between artboards should keep object position.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3790/update-1-1-115</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:40:14 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3790.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Dec 2023 07:28:57 GMT</pubDate><ttl>60</ttl></channel></rss>
