<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.117]]></title><description><![CDATA[<h3>VectorStyler 1.1.117 release notes</h3>
<li>General stability improvements.</li>
<li>Fixed a bug in printing gradients with MacOS printer drivers.</li>
<li>Fixed a bug causing settings and workspace file storage issues.</li>
<li>Highlighting text with formatting imported from SVG file.</li>
<li>Improved paragraph style synchronization.</li>
<li>Fixed a bug in the text editor when editing stretched text shape.</li>
<li>Fixed a bug in editing locked size in Shape panel.</li>
<li>Stroke width brush to handle composite shapes correctly.</li>
<li>Fixed a regression in the fill button accessed from the context panel.</li>
<li>Allow shape references from repeaters.</li>
<li>Fixed a bug in the Shape Corner effect when selecting the corner type.</li>
<li>Ungroup bent objects to keep the correct bending frame.</li>
<li>Fixed a transform pivot point snapping issue.</li>
<li>Undoing convert to curves on groups of clones.</li>
<li>Better character positioning in imported SVG files.</li>
<li>Improved OpenType form handling.</li>
<li>Fixed a bug in using the contour tool on multiple objects.</li>
<li>Place the text cursor to the end when editing the selected text shape.</li>
<li>Uniform icon spacing in panels.</li>
<li>Improved docked panel resizing.</li>
<li>Improved tint handling in the color panel.</li>
<li>Joining multiple objects with the path brush to create the correct shape.</li>
<li>Improved displacement shape effect precision.</li>
<li>Improved contour and offset path effects on text shapes.</li>
<li>Fixed the bucket fill tool cursor positioning problem.</li>
<li>Show associated panels when double clicking on some tools.</li>
<li>Updating fill and stroke options in popover views after undo.</li>
<li>Add DPI value for the selection info of images.</li>
<li>Switch to the previous document when closing a document.</li>
<li>Option to split mesh shape when applying distortion effects or using the mesh inside a vector brush.</li>
<li>Small drag in drawing tools should nit open the modal view.</li>
<li>Better snapping in the reflect tool.</li>
<li>Do not show path extension in the Pen tool when smooth mode is enabled.</li>
<li>Use maximum for proportional scaling.</li>
<li>Allow color palette editing with closed documents.</li>
<li>Fixed the missing icon for the color group heading.</li>
<li>Fixed a bug in arranging artboards into a grid.</li>
<li>Fixed a bug moving and transforming inside composite shapes.</li>
<li>Fixed a crash caused by copying blend objects.</li>
<li>Keep node types after union operation.</li>
<li>Expand Symbol action activation.</li>
<li>Replacing content from the Links panel should update objects correctly.</li>
<li>Panels should not resize after changing preferences.</li>
<li>Fixed a bug in customized toolboxes.</li>
<li>Stroke scaling option to work correctly inside blend objects also.</li>
<li>Maximizing a window by moving should set the correct maximum size (on Windows).</li>
<li>Fixed problem with using Nvidia CUDA on Windows.</li>
<li>Better handling of the right Alt key on Windows.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3882/update-1-1-117</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:40:17 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3882.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jan 2024 19:27:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.117 on Tue, 16 Jan 2024 07:13:02 GMT]]></title><description><![CDATA[<p dir="auto">Really glad to see so many bugs and requests of the last month already been fixed and implemented. Thank you for all the work!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23158</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23158</guid><dc:creator><![CDATA[FastVector]]></dc:creator><pubDate>Tue, 16 Jan 2024 07:13:02 GMT</pubDate></item></channel></rss>
