<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.119]]></title><description><![CDATA[<h3>VectorStyler 1.1.119 release notes</h3>
<li>General stability improvements.</li>
<li>Scatter brush to allow zero width profile nodes.</li>
<li>Improved paragraph style synchronization.</li>
<li>Improved elastic warp effect with larger density.</li>
<li>Exporting text frame with text overflow to PDF should not clip it.</li>
<li>Cloned objects should export correctly to PDF.</li>
<li>Better handling of repeated clone references.</li>
<li>Copy layer names also when copying between documents.</li>
<li>Allow preset removal in the image trace panel.</li>
<li>Fixed a bug in using corner shapes in repeated objects.</li>
<li>Store all artboard and layer options correctly.</li>
<li>Fixed a mouse hovering issue on small scroll knobs.</li>
<li>Allow zero decimal width.</li>
<li>Show current DPI of the selected image.</li>
<li>Allow insertion of glyphs that have no character codes.</li>
<li>Do not scroll the angle field in the canvas and artboards panel.</li>
<li>Improved zigzag effect tool.</li>
<li>Layers panel should update correctly between canvases.</li>
<li>Do not show cursor image when cross-hair cursor is selected.</li>
<li>Store the font name instead of the file name for fonts added in the internal font manager.</li>
<li>Object style should update correctly if original style definition changes.</li>
<li>Joining nodes in union operation should have the correct node type.</li>
<li>Pasting objects into the same document should position them correctly.</li>
<li>Import JPEG file with WebP encoding.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3930/update-1-1-119</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:40:13 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3930.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Jan 2024 10:54:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.119 on Mon, 29 Jan 2024 15:45:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/li-xiao" aria-label="Profile: Li-Xiao">@<bdi>Li-Xiao</bdi></a> Thanks for reporting this, It should be fixed now.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23486</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23486</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 29 Jan 2024 15:45:33 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.119 on Mon, 29 Jan 2024 15:20:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
<a href="https://www.vectorstyler.com/releaselog/#build-11119" rel="nofollow ugc">https://www.vectorstyler.com/releaselog/#build-11119</a></p>
<p dir="auto">Build 1.1.119<br />
Download VectorStyler 1.1.118 for Mac (Intel)<br />
Download VectorStyler 1.1.118 for Mac (Apple Silicon)<br />
Download VectorStyler 1.1.118 for Mac (Universal)<br />
Download VectorStyler 1.1.118 for Windows</p>
<p dir="auto">The downloaded file is also version 1.1.118</p>
<p dir="auto">The online update is correct, and after the update, it is version 1.1.119.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23484</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23484</guid><dc:creator><![CDATA[Li Xiao]]></dc:creator><pubDate>Mon, 29 Jan 2024 15:20:05 GMT</pubDate></item></channel></rss>
