<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.120]]></title><description><![CDATA[<h3>VectorStyler 1.1.120 release notes</h3>
<li>Multiple blend improvements and bug fixes.</li>
<li>Show references also when searching for styles.</li>
<li>Selecting a file in Open Recent should activate document if already opened.</li>
<li>Copy - pasting objects from inside moved layers.</li>
<li>Improved reference style handling.</li>
<li>Copy - pasting objects containing references should handle the reference links correctly.</li>
<li>Fixed possible crash when using Performance sections of the Settings view.</li>
<li>Fixed a bug in the color and style picker tools.</li>
<li>Confirm yes/no alerts with the return key.</li>
<li>Correct arrow direction on outlines with retracted handles.</li>
<li>Snapping in Pen tool when holding the Space key.</li>
<li>External palette to highlight the color of the selected object.</li>
<li>Creating new character and paragraph styles should keep the base style link intact.</li>
<li>Proportional mode button in shape options view.</li>
<li>Scale the character leading with the text.</li>
<li>Improved PDF exporting of certain fonts.</li>
<li>Changing font family should keep the weight.</li>
<li>Improved blending of open shapes.</li>
<li>Converting a frame text to shape text should position the text correctly.</li>
<li>Highlight the last action in the Recent Actions panel.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3954/update-1-1-120</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:40:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3954.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Feb 2024 17:40:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.120 on Sat, 10 Feb 2024 20:58:49 GMT]]></title><description><![CDATA[<p dir="auto">Uploaded a fix with the text resources issue.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23582</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23582</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 10 Feb 2024 20:58:49 GMT</pubDate></item></channel></rss>
