<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[beta 1.2.014]]></title><description><![CDATA[<h3>VectorStyler 1.2.014 release notes</h3>
<li>General stability improvements.</li>
<li>Allow sorting symbols in the Symbols panel.</li>
<li>Keep the the symbols list position fixed.</li>
<li>Fixed symbol tool pressure handling.</li>
<li>Repeater to work correctly if repeated shape is an open path.</li>
<li>Fixed the elastic warp density settings problem.</li>
<li>Fixed glyph handling with missing code mapping.</li>
<li>Number field handling in Canvas and Artboards panel.</li>
<li>Fixed a mesh and warp distortion effect bug.</li>
<li>Fixed a text frame fitting bug with frames having no previous scaling.</li>
<li>Added a new isolation mode to isolate the object and not its content.</li>
<li>Added isolation mode rendering for the non-isolated objects.</li>
<li>Show highlights in stroke dash, stripe and width profile lists.</li>
<li>Allow making new selections with the corner tool by clicking.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3992/beta-1-2-014</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 07:16:11 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3992.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Feb 2024 07:42:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 21:25:01 GMT]]></title><description><![CDATA[<p dir="auto">@Pat said in <a href="/forum/post/23770">beta 1.2.014</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Once I've selected an object with the Shape tool, I can no longer modify it with the Node tool.</p>
</blockquote>
<p dir="auto">A "Convert to Curves" will make the shape editable again.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23772</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23772</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 Mar 2024 21:25:01 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 17:09:07 GMT]]></title><description><![CDATA[<p dir="auto">@Pat said in <a href="/forum/post/23770">beta 1.2.014</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">I opened a bug on this one.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23771</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23771</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 Mar 2024 17:09:07 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 17:01:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Once I've selected an object with the Shape tool, I can no longer modify it with the Node tool.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23770</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23770</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 01 Mar 2024 17:01:13 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 13:43:19 GMT]]></title><description><![CDATA[<p dir="auto">@Pat Looks like there is a bug when scaling shape. The issue is fixed with undoing, or replacing (with shape copy / paste) the shape of the clipping group.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23767</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23767</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 Mar 2024 13:43:19 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 13:19:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> ... got an issue : the clipping object suddenly disappeared. I'll sent you the file in case it's usefull.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23766</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23766</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 01 Mar 2024 13:19:48 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 13:16:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> ok understood  <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" />  &amp; no need for the 'lock/unlock children' feature then.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23765</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23765</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 01 Mar 2024 13:16:30 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 12:57:48 GMT]]></title><description><![CDATA[<p dir="auto">@Pat said in <a href="/forum/post/23762">beta 1.2.014</a>:</p>
<blockquote>
<p dir="auto">that's what I'd do if I wanted to modify the clipped object</p>
</blockquote>
<p dir="auto">Yes, but with different tools:</p>
<li>the first tool is to modify the whole group (clipped content also).</li>
<li>the third tool is to modify the clipping shape (without the content).</li>
<p dir="auto"><img src="/forum/assets/uploads/files/1709297826799-tools.png" alt="0_1709297826175_tools.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/23763</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23763</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 Mar 2024 12:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 12:43:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thanks &amp; if I understand your idea correctly <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f914.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--thinking_face" style="height:23px;width:auto;vertical-align:middle" title=":thinking_face:" alt="🤔" /> : that's what I'd do if I wanted to modify the clipped object, but if I want to modify the dimensions of the object in which the clipped object is, I can't do it without unclipping the object and reclipping it again.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23762</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23762</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 01 Mar 2024 12:43:05 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 08:42:21 GMT]]></title><description><![CDATA[<p dir="auto">@Pat said in <a href="/forum/post/23759">beta 1.2.014</a>:</p>
<blockquote>
<p dir="auto">Thanks, no way then to maintain the dimensions of the clipped object ?</p>
</blockquote>
<p dir="auto">I added this to the feature request list. No lock/unlock yet in 1.2</p>
<p dir="auto">But you can use the node editor tool to change the clipping shape.<br />
Also: if you use the shape selector tool (grouped with the regular transform tool), and select the clipping group with that, it will select and transform its shape only.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23760</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23760</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 Mar 2024 08:42:21 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 08:38:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thanks, no way then to maintain the dimensions of the clipped object ? Well, it would be interesting. I often use this feature in ADesigner in my graphics ("Lock/unlock children").</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23759</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23759</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 01 Mar 2024 08:38:46 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 08:35:31 GMT]]></title><description><![CDATA[<p dir="auto">@Pat Got the file, but I just realized that I was thinking of another case.<br />
So the rectangle is already inside when the clipping group is scaled?<br />
In that case, yes the content is always scaled.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23758</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23758</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 Mar 2024 08:35:31 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 08:22:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Yes, drag-drop from the layer panel. Issue reproducible, new file sent <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/23757</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23757</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 01 Mar 2024 08:22:17 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 08:16:23 GMT]]></title><description><![CDATA[<p dir="auto">@Pat There is no need to lock to maintain the dimensions. Did you use drag&amp;drop to move the rectangle into the clipping group?<br />
Not sure what could cause this issue, can you send me the file? Thanks!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23756</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23756</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 Mar 2024 08:16:23 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 08:07:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> while testing the isolation mode, I realise that I don't know (anymore?) how to maintain the dimensions of an object clipped into another? clicking on the lock doesn't maintain its dimensions. Thanks <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1709280440829-o1.jpg" alt="0_1709280440609_o1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1709280447092-o2.jpg" alt="0_1709280447032_o2.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1709280453113-o3.jpg" alt="0_1709280453054_o3.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/23755</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23755</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 01 Mar 2024 08:07:53 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 07:49:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I'm not used to working in isolation mode, so I'm sorry if I don't quite understand the nuances of this; when you double-click on an object in VS, it seems to me that we're in isolation mode (?) but the object can't undergo any transformation... so what's the point of this?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23754</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23754</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 01 Mar 2024 07:49:44 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Fri, 01 Mar 2024 06:30:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> said in <a href="/forum/post/23752">beta 1.2.014</a>:</p>
<blockquote>
<p dir="auto">Should they have the same options in both places?</p>
</blockquote>
<p dir="auto">The toolbox contains the Isolate Selected only, the "Outside Isolation" is not shown in the menu (will be added later).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23753</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23753</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 Mar 2024 06:30:53 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Thu, 29 Feb 2024 23:22:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I like where this is headed! I can see this being very useful.</p>
<p dir="auto">Is it just me or do the options in the top right side of the menubar not fully correspond with those listed in the "select&gt; isolate selected/isolate inside"? Should they have the same options in both places?</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1709247910858-1d03193f-b4a1-415d-8caa-b6d85c9e3d0c-bld-2024-02-29-at-18.04.50.png" alt="0_1709247909759_1d03193f-b4a1-415d-8caa-b6d85c9e3d0c-BLD 2024-02-29 at 18.04.50.png" class=" img-fluid img-markdown" /><br />
<img src="/forum/assets/uploads/files/1709247833430-a8c0a2e9-c391-432a-9a35-708791c6df9a-bld-2024-02-29-at-18.02.05.png" alt="0_1709247833264_a8c0a2e9-c391-432a-9a35-708791c6df9a-BLD 2024-02-29 at 18.02.05.png" class=" img-fluid img-markdown" /><br />
<img src="/forum/assets/uploads/files/1709247853179-7c826e87-3a2f-4417-880a-e614cc6aad13-bld-2024-02-29-at-18.04.03.png" alt="0_1709247852942_7c826e87-3a2f-4417-880a-e614cc6aad13-BLD 2024-02-29 at 18.04.03.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/23752</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23752</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 29 Feb 2024 23:22:26 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Thu, 29 Feb 2024 15:58:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> said in <a href="/forum/post/23750">beta 1.2.014</a>:</p>
<blockquote>
<p dir="auto">Added a new isolation mode to isolate the object and not its content.</p>
</blockquote>
<p dir="auto">Yes. The idea is that if we want to edit an object (or multiple objects) but not interfere with other objects then this isolation mode does that.<br />
The previous isolation mode edited the objects inside the isolated object.<br />
This new isolation mode edits the isolated object (not its content).</p>
<p dir="auto">This new isolation mode is accessible from the menu (same as the other) but also from the toolbox (top row, towards the end).</p>
<blockquote>
<p dir="auto">Added isolation mode rendering for the non-isolated objects.</p>
</blockquote>
<p dir="auto">Here we can select how the objects outside of isolation are displayed. Both for Isolate Inside and Isolate Selected modes.<br />
Previously, the other objects were dimmed, now we can have hidden, outline, dimmed or normal display.<br />
The button to select this is in the toolbox just before the drawing place icon.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23751</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23751</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 29 Feb 2024 15:58:11 GMT</pubDate></item><item><title><![CDATA[Reply to beta 1.2.014 on Thu, 29 Feb 2024 15:35:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/23747">beta 1.2.014</a>:</p>
<blockquote>
<p dir="auto">Added a new isolation mode to isolate the object and not its content.<br />
</blockquote>
<p dir="auto">Thanks for the new update! Would you be wiling to elaborate on how to utilize these new features?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/23750</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/23750</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 29 Feb 2024 15:35:35 GMT</pubDate></item></channel></rss>
