<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.2.018]]></title><description><![CDATA[<h3>VectorStyler 1.2.018 release notes</h3>
<li>General stability improvements.</li>
<li>Improved startup speed.</li>
<li>Improved font handling in PDF exporting.</li>
<li>Improved offset path on complex shapes.</li>
<li>Select path objects</li>
<li>Flip intersecting selection mode by pressing the E key while drawing the selection region.</li>
<li>Converting clones to curves to expand clones first.</li>
<li>Placing a symbol into a group should position the symbol correctly.</li>
<li>Allow mesh gradients with spot color transitions.</li>
<li>Allow layer unlocking with Unlock All.</li>
<li>Allow access to both group and repeater content on the same object.</li>
<li>Fixed issues in using blended shape in a repeater.</li>
<li>Fixed a crash in the Stroke Dash view caused by swiping on the gap field.</li>
<li>Fixed artifacts in rendering when using Render as Image on objects.</li>
<li>Expanding repeater with transformed symbol objects, to position symbols correctly.</li>
<li>Fixed a bug in undoing of Paragraph Style changes.</li>
<li>Fixed a text input bug in layers panel.</li>
<li>Allow delesect all shortcut in Layers panel also.</li>
<li>Fixed a measurement field size on the Variable Values panel.</li>
<li>Fixed a crash when placing a displacement effect at the bottom of the object stack.</li>
<li>Fixed a stroke alignment problem.</li>
<li>Improved display scaling support with multiple displays on Windows.</li>
<li>Fixed the Tab key use on Windows for moving between fields.</li>
<li>Changed the Isolate Layer modifier on Windows to Alt.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/4093/update-1-2-018</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 06:20:49 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4093.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Mar 2024 06:37:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.2.018 on Thu, 28 Mar 2024 21:13:04 GMT]]></title><description><![CDATA[<p dir="auto">Agreed. I feel inspired to write up bug and feature requests when I run into them, because I know they will actually get seen and worked on. I'm a software developer myself, so I know how valuable it can be to have testers who give good feedback, so I want to do my part to be part of that.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/24279</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/24279</guid><dc:creator><![CDATA[LoginError]]></dc:creator><pubDate>Thu, 28 Mar 2024 21:13:04 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.018 on Thu, 28 Mar 2024 21:03:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/loginerror" aria-label="Profile: LoginError">@<bdi>LoginError</bdi></a> We get pretty spoiled by the developer. The fast turnaround with fixes and improvements further inspires me to share as many issues and ideas as I can. It's always fun to see a fix or new feature implemented in the new build when released</p>
]]></description><link>https://www.vectorstyler.com/forum/post/24278</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/24278</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 28 Mar 2024 21:03:36 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.018 on Thu, 28 Mar 2024 20:22:39 GMT]]></title><description><![CDATA[<p dir="auto">I just want to say how much I appreciate your quick responses to bug reports and its nice to see several of the issues I reported being fixed in the patch notes. It is very rare to have developers that actually interact with the community and hop on bug fixes right away, especially in the art/design industry. <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/2764.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--heart" style="height:23px;width:auto;vertical-align:middle" title="&lt;3" alt="❤" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/24275</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/24275</guid><dc:creator><![CDATA[LoginError]]></dc:creator><pubDate>Thu, 28 Mar 2024 20:22:39 GMT</pubDate></item></channel></rss>
