<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.2.019]]></title><description><![CDATA[<h3>VectorStyler 1.2.019 release notes</h3>
<li>General stability improvements.</li>
<li>Show document preset groups separately in template list.</li>
<li>Contour effect around clipping groups to handle content correctly.</li>
<li>Number field scrolling to use rounded numbers in new document view.</li>
<li>Intersection mode flipping shortcut to be temporal.</li>
<li>Eraser tool improvements.</li>
<li>Moving multiple stroke width nodes.</li>
<li>Update glyph panel on character selection change.</li>
<li>Allow smaller image limit in exporting.</li>
<li>Improved support for number variables in repeaters.</li>
<li>Improved shape effect support on repeaters.</li>
<li>Added a repeater object selection mode that uses background intensity levels.</li>
<li>Improved number field input with unit name.</li>
<li>Allow selecting fill opacity for text in Appearance panel.</li>
<li>Added shortcuts for color and gradient selection.</li>
<li>Additional OpenType glyph group support in Glyphs panel.</li>
<li>Improved AI file format support.</li>
<li>Added a rotate option to polygonal spiral.</li>
<li>Improved display resolution support.</li>
<li>Highlight current font when using the "All Fonts" collection.</li>
<li>Options to preserve color luminosity or other properties in color filters.</li>
<li>New actions to restore default shortcuts, menus and toolboxes.</li>
<li>Allow applying paragraph preset from the paragraph panel drop down list.</li>
<li>Updated Appearance panel documentation.</li>
<li>Expanding scatter brush with noise should position objects correctly.</li>
<li>Local shape effect on appearance item to work for text shapes also.</li>
<li>Improved display of local style effects for text shapes.</li>
<li>Fixed several issues with the Guidelines panel.</li>
<li>Fixed a bug in the Envelope shape selection.</li>
<li>Allow the "Enter" key as a shortcut in the shortcut editor view.</li>
<li>Improved display scaling support on Windows (no flickering borders).</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/4150/update-1-2-019</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 18:12:46 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4150.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Apr 2024 06:18:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.2.019 on Thu, 11 Apr 2024 07:27:19 GMT]]></title><description><![CDATA[<p dir="auto">Thank you so much for all the hard work! I just cleared all my 'unread' posts and returned to find a ton waiting again, all marked as fixes for this release. Exciting to see so much work done, VS is getting better and better!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/24633</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/24633</guid><dc:creator><![CDATA[syllie]]></dc:creator><pubDate>Thu, 11 Apr 2024 07:27:19 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.019 on Thu, 11 Apr 2024 06:31:36 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/24615</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/24615</guid><dc:creator><![CDATA[creative]]></dc:creator><pubDate>Thu, 11 Apr 2024 06:31:36 GMT</pubDate></item></channel></rss>
