<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.023 RC2 with CJK support]]></title><description><![CDATA[<h3>VectorStyler 1.0.023 RC2 release notes</h3>
<p dir="auto">CJK features must be enabled first with the Preferences -&gt; Editing Options -&gt; Enable east-Asian Options</p>
<li>Improved: added Japanese typography features.</li>
<li>Fixed: Japanese text input on Windows.</li>
<li>Fixed: pasting text into text frames on Windows.</li>
<li>Fixed: detecting system installed TTC fonts.</li>
<li>Fixed: glyph panel was very slow with fonts containing large number of glyphs.</li>
<li>Fixed: creating palette from an image using the palette panel menu command resulted in wrong color modes (and names).</li>
<li>Fixed: append new colors from selection or image directly into the palette. Use menu option to enable group creation.</li>
<li>Fixed: tooltips on color names in list mode of palette panel were wrong.</li>
<li>Fixed: enable scrollbar in glyph panel.</li>
<li>Fixed: node tool could could select parametric shapes for editing.</li>
<li>Fixed: cannot select original node of a path if corner was rounded.</li>
<li>Fixed: correct highlight of Japanese characters in text editor fields.</li>
<li>Fixed: zero width stroke filled with tiling pattern.</li>
<li>Fixed: set kerning without highlight, at the cursor position.</li>
<li>Fixed: gap slider of ellipse shape did not use correct values.</li>
<li>Fixed: option+drag guideline from ruler should not create a duplicate under the ruler.</li>
<li>Fixed: option+drag from ruler corner should adjust ruler origin.</li>
<li>Fixed: update artboard selection drop down when new artboards are created.</li>
<li>Fixed: confirm font selection by pressing enter.</li>
<li>Fixed: glyph panel did not show all possible alternates.</li>
<li>Fixed: exporting SVG should add DTD heading.</li>
<li>Fixed: indicate isolation inside an object with an additional label.</li>
<li>Fixed: update brush styles panel preview when new document is created.</li>
<li>Fixed: default vector brush color should be the current outline color.</li>
<li>Fixed: variable font instance names were not retrieved properly.</li>
<li>Fixed: setting blend mode for stroke only did not work.</li>
<li>Fixed: font selection did not always apply to the selected text.</li>
<li>Fixed: scaling selected nodes from a path may scale the starting node twice.</li>
<li>Fixed: break apart on multiple selections did not work correctly.</li>
<li>Fixed: importing stroke cap type from PDF.</li>
<li>Fixed: detecting clicks when using tablet on Windows.</li>
<li>Fixed: full screen mode should keep the menu bar on Windows.</li>
<li>Fixed: select and close in popup menus when the mouse is released.</li>
<li>Fixed: support for special characters in file names on Windows.</li>
<li>Fixed: show all supported file types in open dialog on Windows.</li>
<li>Fixed: workspace file extension was not added.</li>
<li>Fixed: add system color profile path for Windows.</li>
<li>Fixed: broken gradient opacity in CMYK documents.</li>
<li>Fixed: stroke rendering with very sharp joins was broken.</li>
<li>Fixed: option+drag to insert the duplicate after the selected object.</li>
<li>Fixed: convert first segment type when first node of an open path is selected.</li>
<li>Fixed: corner tool combined with transform tool did not work.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/436/update-1-0-023-rc2-with-cjk-support</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:14 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/436.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Apr 2021 18:32:39 GMT</pubDate><ttl>60</ttl></channel></rss>
