<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[About the CJK features]]></title><description><![CDATA[<p dir="auto">So finally, the CJK features (beta) are available.<br />
First thing: CJK must be enabled with the Preferences -&gt; Editing Options -&gt; Enable East-Asian Options</p>
<p dir="auto">The user manual will be updated later, next is a brief list.</p>
<p dir="auto">The following features are available:</p>
<ol>
<li>
<p dir="auto">Character Mapping: this is specific to VS, and it is used by most of the other features. Basically it organizes character codes into user defined classes. A couple of character map presets are predefined, but it is possible to customize and create new ones.</p>
</li>
<li>
<p dir="auto">Rotating roman or other half-width characters. Enabled by default, can be set in the paragraph options. Can be customized with user defined character maps.</p>
</li>
<li>
<p dir="auto">Tatechuyoko: both manual (character option) and automatic (in paragraph option). Typically set from the Character panel menu.</p>
</li>
<li>
<p dir="auto">Warichu (character option): set from the Character panel menu.</p>
</li>
<li>
<p dir="auto">Ruby (character option): created from the Character panel menu. Once created, the Ruby text is edited in place in the text editor and can be styled as any other text.</p>
</li>
<li>
<p dir="auto">Mojikumi (paragraph option): there are some basic mojikumi presets available in the style field (upper right corner). When opened, the mojikumi view list may be empty, select a preset to edit.<br />
Mojikumi user character mappings, the <em>Basic Mojikumi</em> and <em>Mojikumi Mapping</em> are two character mapping presets suitable for mojikumi. The predefined mojikumi presets use the basic mapping. More complex mappings can be set up by the user (or will be included later).<br />
The mojikumi style must be selected in the paragraph option to be used. There is a lot new and different here, I will elaborate more in the documentation.<br />
BTW: there are no priorities, instead it is possible to define different mojikumi settings at different stretching levels.</p>
</li>
<li>
<p dir="auto">Aki and tsume (character option).</p>
</li>
<li>
<p dir="auto">Kinsoku (paragraph option): the styles are edited in the Kinsoku Options view. The joining classes (what not to break) can be customized with user defined character mappings.</p>
</li>
<li>
<p dir="auto">Hanging punctuation: added this feature for roman also. Kinsoku defines the hanging punctuation, but it must be enabled at paragraph level. (burasagari options are set in the <em>Hanging Mode</em> paragraph panel menu, or the first drop down in the paragraph -&gt; general options -&gt; hanging field)</p>
</li>
<li>
<p dir="auto">Kenten (character option): it is also possible to select inline symbols or shape references for custom kenten glyphs.</p>
</li>
<li>
<p dir="auto">Shatai (character option)</p>
</li>
</ol>
<p dir="auto">Existing documents do not have the correct stretching options for Japanese typography. This can be fixed, by editing the stretching style of the paragraph, and removing <em>Word</em> from the last level and add <em>Spacing</em> instead.<br />
Mojikumi stretching is automatically added if selected in the paragraph options.</p>
<p dir="auto">Some other observations:</p>
<li>the default <em>Spacing</em> stretching mode (automatically set in new documents) can be customized with character mappings set in the paragraph options.</li>
<li>characters can be skipped by kenten, and this is also defined by character mappings.</li>
<li>text tools have been changed to have separate vertical text creation tools.</li>
<p dir="auto">Please report any issues with examples to help better communicate the problem.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/437/about-the-cjk-features</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:13 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/437.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Apr 2021 18:58:26 GMT</pubDate><ttl>60</ttl></channel></rss>
