<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Some Select sub-menus under the Select menu misfiring]]></title><description><![CDATA[<p dir="auto">Some Select sub-menus under the Select menu will not work if artwork is grouped, eg Select By Style to select a similar fill colour. Ideally, this should work regardless of the artwork being grouped or ungrouped.</p>
<p dir="auto">In some instances even the Shape Type &gt; Text Shape fails to select text shape type even if it's not grouped.</p>
<p dir="auto">I'm not so sure about the other selection options under the Select menu but will progressively report over time.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4376/some-select-sub-menus-under-the-select-menu-misfiring</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 09:10:09 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4376.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Jun 2024 20:41:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Some Select sub-menus under the Select menu misfiring on Sun, 16 Jun 2024 17:15:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thank you!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/25751</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/25751</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Sun, 16 Jun 2024 17:15:00 GMT</pubDate></item><item><title><![CDATA[Reply to Some Select sub-menus under the Select menu misfiring on Sun, 16 Jun 2024 10:49:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> These selection modes also depend on options set in the Select -&gt; Options menu.</p>
<p dir="auto">In the workspace file I received by email, the "Select Siblings" is enabled, meaning that only object on the same layer (and level) or inside the same group are selected.</p>
<p dir="auto">Disable this option and then all objects are searched for selection.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/25739</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/25739</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 16 Jun 2024 10:49:58 GMT</pubDate></item></channel></rss>
