<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Contour Effect Issues]]></title><description><![CDATA[<p dir="auto">A few observations and questions. See pdf...<br />
<a href="/forum/assets/uploads/files/1720447088173-contour-effect-issues.pdf">0_1720447086473_Contour Effect Issues.pdf</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4482/contour-effect-issues</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 16:28:57 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4482.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jul 2024 13:47:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Contour Effect Issues on Tue, 09 Jul 2024 09:12:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> I will try to find a solution for this.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26258</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26258</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 09 Jul 2024 09:12:50 GMT</pubDate></item><item><title><![CDATA[Reply to Contour Effect Issues on Tue, 09 Jul 2024 09:06:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/26255">Contour Effect Issues</a>:</p>
<blockquote>
<p dir="auto">The original and the contour are separate objects. Group these two and then scale.</p>
</blockquote>
<p dir="auto">Thanks, but I'm left with the following questions... (see pdf)<br />
<a href="/forum/assets/uploads/files/1720515979650-contour-effect-scaling-ii.pdf">0_1720515978526_Contour Effect scaling II.pdf</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/26257</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26257</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Tue, 09 Jul 2024 09:06:52 GMT</pubDate></item><item><title><![CDATA[Reply to Contour Effect Issues on Mon, 08 Jul 2024 19:01:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> I replicated the bug, will be fixed in the next build.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26256</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26256</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 08 Jul 2024 19:01:04 GMT</pubDate></item><item><title><![CDATA[Reply to Contour Effect Issues on Mon, 08 Jul 2024 18:00:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a></p>
<blockquote>
<p dir="auto">Issue 1</p>
</blockquote>
<p dir="auto">Yes, this is intended. The original object is still selectable and can be copied (similar to Blend).</p>
<blockquote>
<p dir="auto">Issue 2</p>
</blockquote>
<p dir="auto">No this seems to be a bug, send me the file.</p>
<blockquote>
<p dir="auto">Issue 3</p>
</blockquote>
<p dir="auto">The original and the contour are separate objects. Group these two and then scale.<br />
Same with the blend effect: group the 3 objects (starting, blend, ending).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26255</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26255</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 08 Jul 2024 18:00:41 GMT</pubDate></item></channel></rss>
