<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.2.031 Organizing layers]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/26272">update 1.2.031</a>:</p>
<blockquote>
<p dir="auto">This is visible only when an object with fill is selected.<br />
About organizing layers: there are two features (one already existed with a minor bug).<br />
The first (new) feature is the "Place Before/After/Inside" commands from the Layers panel menu.</p>
<p dir="auto">assuming that the on canvas and Layers panel selection are not synchronized (here is the advantage)<br />
select some objects on the canvas (with the regular selection tools).<br />
scroll to and highlight an object in the Layers panel (this will have the strong blue highlight).<br />
then the "Place Before/After/Inside" commands of the Layers panel menu will place the selection on the canvas before/after/inside the highlighted object.</p>
<p dir="auto">The other (existing) feature is using multiple Layers panels. In the Layers panel menu use the "Open New Panel" command to open another layers panel. Now you can position each list differently and use drag &amp; drop to move or copy objects between the panels.<br />
There are also the "Open with..." layer panel opening modes that will fix the opened panel content to the current document (or location) and can be used to copy objects into (or from) an other document.</p>
</blockquote>
<p dir="auto">Sidetrack this topic</p>
<p dir="auto">Transformed Fill, found it!</p>
<p dir="auto">Organizing layers<br />
Without making it more difficult with multi layer panels, my point in the aforementioned post was moving objects with layers in closed state. The mentioned functionalities do not solved this. Or am I not seeing that correctly?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4487/update-1-2-031-organizing-layers</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 08:21:37 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4487.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Jul 2024 16:41:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.2.031 Organizing layers on Wed, 10 Jul 2024 12:05:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Additionally the extended luxury version<br />
Possibly with a grayed-out signaling to indicate if not applicable...<br />
<img src="/forum/assets/uploads/files/1720612994058-37be3893-0648-4f45-a4a1-99283520bdfd-image.png" alt="0_1720612992688_37be3893-0648-4f45-a4a1-99283520bdfd-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/26296</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26296</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Wed, 10 Jul 2024 12:05:40 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.031 Organizing layers on Wed, 10 Jul 2024 11:13:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> said in <a href="/forum/post/26293">update 1.2.031 Organizing layers</a>:</p>
<blockquote>
<p dir="auto">Suggestion...</p>
</blockquote>
<p dir="auto">This might work, I will try it.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26295</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26295</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 10 Jul 2024 11:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.031 Organizing layers on Wed, 10 Jul 2024 10:06:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/26284">update 1.2.031 Organizing layers</a>:</p>
<blockquote>
<p dir="auto">The panel is already too crowded.</p>
</blockquote>
<p dir="auto">Suggestion...<br />
<img src="/forum/assets/uploads/files/1720605946004-79b252e7-60ab-4013-9f39-cb034b9310bc-image-resized.png" alt="0_1720605944670_79b252e7-60ab-4013-9f39-cb034b9310bc-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/26293</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26293</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Wed, 10 Jul 2024 10:06:07 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.031 Organizing layers on Tue, 09 Jul 2024 19:51:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> said in <a href="/forum/post/26281">update 1.2.031 Organizing layers</a>:</p>
<blockquote>
<p dir="auto">in the panel itself.</p>
</blockquote>
]]></description><link>https://www.vectorstyler.com/forum/post/26284</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26284</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 09 Jul 2024 19:51:07 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.031 Organizing layers on Tue, 09 Jul 2024 18:19:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
That clears up my confusion. Thanks!</p>
<p dir="auto">I'm left with the question why Transformed Fills cannot live with its friends Transformed Each -Line, -Effects in the panel itself.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26281</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26281</guid><dc:creator><![CDATA[Ayo]]></dc:creator><pubDate>Tue, 09 Jul 2024 18:19:08 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.031 Organizing layers on Tue, 09 Jul 2024 17:00:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> The reason for this solution is that it was a low risk (easy to implement) addition and mostly it was already there. For 1.3 we can have a more advanced approach.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26277</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26277</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 09 Jul 2024 17:00:56 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.031 Organizing layers on Tue, 09 Jul 2024 16:52:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ayo" aria-label="Profile: Ayo">@<bdi>Ayo</bdi></a> said in <a href="/forum/post/26275">update 1.2.031 Organizing layers</a>:</p>
<blockquote>
<p dir="auto">The mentioned functionalities do not solved this.</p>
</blockquote>
<p dir="auto">No they do not.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26276</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26276</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 09 Jul 2024 16:52:05 GMT</pubDate></item></channel></rss>
