<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.025 RC2]]></title><description><![CDATA[<h3>VectorStyler 1.0.025 RC2 release notes</h3>
<li>Improved: anchor node tool.</li>
<li>Improved: create boundary path from selection.</li>
<li>Improved: allow boundary mode in contour effect.</li>
<li>Improved: add boundary mode to destructive offset path effect.</li>
<li>Improved: set combination mode when referencing a group for a shape style.</li>
<li>Improved: allow negative font scaling.</li>
<li>Improved: remember search field state in color palette panel.</li>
<li>Improved: allow tinted global color addition to the main color palette.</li>
<li>Improved: allow separate mask input for the inner shadow effect.</li>
<li>Improved: right click in color palette to set alternate (stroke) color.</li>
<li>Improved: right click in color wheel to set alternate (stroke) color.</li>
<li>Improved: show and set guideline coordinates and rotation in the transform panel, when no object is selected.</li>
<li>Improved: snap guidelines to artboard margin and center when artboard snapping is enabled.</li>
<li>Improved: palette panel menu command to remake palette to RGB or CMYK (can be used after document color mode is changed, to reset the palette).</li>
<li>Improved: select ruler units by right clicking on ruler.</li>
<li>Improved: option to change current style (fill or stroke) opacity only, instead of whole object opacity in color and palette panels (selected from panel menu).</li>
<li>Improved: lock panels (application menu) to block docking.</li>
<li>Improved: create guidelines around the bounding box of the selected objects (command is in Guidelines panel menu).</li>
<li>Fixed: text on path may show the wrong outline for highlight.</li>
<li>Fixed: stroke overprint was not working.</li>
<li>Fixed: expanding stroke containing zero width dashes.</li>
<li>Fixed: expanding zero width stroke with dashes.</li>
<li>Fixed: output SVG scaling in a single matrix.</li>
<li>Fixed: importing multiple styles on an object in AI files.</li>
<li>Fixed: duplicate objects placed above selected objects when moving with Option+.</li>
<li>Fixed: remove full screen for document view on Windows. Use maximize window instead.</li>
<li>Fixed: show input method candidate popup next to the text.</li>
<li>Fixed: baseline with some vertical fonts was wrong.</li>
<li>Fixed: problem in shape union.</li>
<li>Fixed: transform handles (when enabled) may get hidden when moving cursor in text.</li>
<li>Fixed: gradient mesh shape persists on new objects (should use default fill color).</li>
<li>Fixed: editing shapes inside composite shapes.</li>
<li>Fixed: auto fill file name when saving presets.</li>
<li>Fixed: gradient tool handles should have special cursor.</li>
<li>Fixed: name of shortcut of the preferences command in menu.</li>
<li>Fixed: show a default tool tip for the no fill palette item.</li>
<li>Fixed: joining two nodes may move the selection to the wrong place.</li>
<li>Fixed: allow separation with default printer color mode, if document color mode is CMYK.</li>
<li>Fixed: set no fill from color palette when shown in a popover view.</li>
<li>Fixed: combining shapes and text shape must set even odd fill mode.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/453/update-1-0-025-rc2</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:17 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/453.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 May 2021 17:06:09 GMT</pubDate><ttl>60</ttl></channel></rss>
