<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Live text cannot be erased with command-x and copying with command-c does not work either]]></title><description><![CDATA[<p dir="auto">I have a line of live text with two words on the line. <a href="https://share.cleanshot.com/dzmzzkYJ" rel="nofollow ugc">I tried to highlight the second word and use command-x to cut it. This did not work.</a> I did find that after highlighting the word I wanted to remove and pressing delete, that did work properly.  However, when I then attempt command-v to paste the previously cut portion of the live text, it was not in memory to be pasted at all.<br />
I also tried using command-c to copy the text and then paste it but that also did not work.</p>
<p dir="auto">I was able to use the mouse to click on the applicable options under the edit&gt;cut/copy/paste</p>
<p dir="auto">I would expect that command-x should cut a piece of highlighted live text and retain it in memory while removing it from the line of text.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4566/live-text-cannot-be-erased-with-command-x-and-copying-with-command-c-does-not-work-either</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 21:40:27 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4566.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Aug 2024 22:12:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Live text cannot be erased with command-x and copying with command-c does not work either on Fri, 02 Aug 2024 07:01:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I opened a bug on this.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26685</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26685</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 02 Aug 2024 07:01:24 GMT</pubDate></item></channel></rss>
