<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.2.036]]></title><description><![CDATA[<h3>VectorStyler 1.2.036 release notes</h3>
<li>General stability improvements.</li>
<li>Improved color font exporting.</li>
<li>Fixed an error when importing blend objects from Illustrator EPS files.</li>
<li>Improved text on path movement.</li>
<li>Allow duplication of text on path object when moving.</li>
<li>Improved data source handling.</li>
<li>Fixed a bug with copy paste in the text editor.</li>
<li>Select default color when changing color from the context panel.</li>
<li>Do not allow opacity change with numeric keys on locked objects.</li>
<li>Option(Alt) click on layers to hide / show all others.</li>
<li>Fixed an error in separating paths in the eraser tool.</li>
<li>Selecting gradient presets in the gradient color editor.</li>
<li>Exporting vertical type in PDF should not break horizontal type.</li>
<li>Allow images in artistic brush.</li>
<li>Improved shape corner handling with complex shapes.</li>
<li>Frame selecting inside an empty shape should not select the shape.</li>
<li>Retain transform box when flipping.</li>
<li>Fixed a bug in importing text from SVG files.</li>
<li>Allow stacking multiple SVG image effects.</li>
<li>Fixed the default resolution of JPEG files.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/4583/update-1-2-036</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 16:24:19 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4583.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Aug 2024 08:43:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.2.036 on Thu, 15 Aug 2024 13:12:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Great list of updates for VS! Text on a path movement is much improved and duplication on the path is a very helpful addition.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26791</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26791</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 15 Aug 2024 13:12:19 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.036 on Thu, 15 Aug 2024 09:02:13 GMT]]></title><description><![CDATA[<p dir="auto">Splendid update, as per usual. Thank you.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26790</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26790</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Thu, 15 Aug 2024 09:02:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.036 on Wed, 14 Aug 2024 14:09:07 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for this. Downloading now.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26777</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26777</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Wed, 14 Aug 2024 14:09:07 GMT</pubDate></item></channel></rss>
