<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Glitches in Transform tab]]></title><description><![CDATA[<p dir="auto">The transform tab needs a serious overhaul. The dropdown options appear confusing, redundant and the values manipulation either doesn't apply or applies distorted to object.</p>
<p dir="auto"><a href="/forum/assets/uploads/files/1723794810171-transform-tab-troubles.vstyler">0_1723794809901_Transform-tab-troubles.vstyler</a></p>
<p dir="auto"><img src="https://i.postimg.cc/9fdwhBLt/Transform-tab-troubles.gif" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4588/glitches-in-transform-tab</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 08:36:51 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4588.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Aug 2024 07:54:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Glitches in Transform tab on Thu, 22 Aug 2024 08:05:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
"other transforms already applied" -- makes sense, thank you<img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title="😊" alt="😊" /><br />
Yet one should expect transformation always applies to the latest effect layer/state in the stack only (retaining the objects current visible appearance).</p>
<p dir="auto">"... the transform pivot selection is disabled". Cool, very helpful. Got it.<br />
Though I must confess, that the options in the rightclick-dropdwn confuses me with combinated layer groups and textframes. As occasional user (and user of other vectordrawing programs) one have to click and try quite a lot to get the right setup ie. when rotating shapes.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1724313857080-387c8c6d-e16a-45ee-8b05-15a0efa88ecb-billede.png" alt="0_1724313856157_387c8c6d-e16a-45ee-8b05-15a0efa88ecb-billede.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/26850</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26850</guid><dc:creator><![CDATA[Raaskot]]></dc:creator><pubDate>Thu, 22 Aug 2024 08:05:55 GMT</pubDate></item><item><title><![CDATA[Reply to Glitches in Transform tab on Thu, 22 Aug 2024 04:07:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/raaskot" aria-label="Profile: Raaskot">@<bdi>Raaskot</bdi></a> The text frame has multiple other transforms already applied, and this causes the text distortion.<br />
Use the Effects -&gt; Remove All Shape Effects command to clear these.</p>
<p dir="auto">For point (2), the pivot point is used in the transform panel only if the transform pivot selection is disabled in the upper-left pivot knob, this can be done by clicking on the selected pivot knob.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26848</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26848</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 22 Aug 2024 04:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to Glitches in Transform tab on Wed, 21 Aug 2024 17:17:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
The file is attached in OP.</p>
<p dir="auto">Regards, raaskot</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26847</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26847</guid><dc:creator><![CDATA[Raaskot]]></dc:creator><pubDate>Wed, 21 Aug 2024 17:17:17 GMT</pubDate></item><item><title><![CDATA[Reply to Glitches in Transform tab on Wed, 21 Aug 2024 13:29:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/raaskot" aria-label="Profile: Raaskot">@<bdi>Raaskot</bdi></a> I'm trying to replicate this with default text frame attributes, but here the type is not distorted.<br />
Can you send me the file shown in that example? Thanks!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26841</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26841</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 21 Aug 2024 13:29:14 GMT</pubDate></item><item><title><![CDATA[Reply to Glitches in Transform tab on Fri, 16 Aug 2024 10:04:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/raaskot" aria-label="Profile: Raaskot">@<bdi>Raaskot</bdi></a> I will try to replicate and fix these.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26798</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26798</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 16 Aug 2024 10:04:40 GMT</pubDate></item><item><title><![CDATA[Reply to Glitches in Transform tab on Fri, 16 Aug 2024 08:56:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
Sorry, I was unclear:</p>
<ol>
<li>type is distorted when changing x-values (proportional on)</li>
<li>cannot make rotate values respect altered centerpoint</li>
</ol>
<p dir="auto"><img src="/forum/assets/uploads/files/1723797836618-6b5a0baf-ccbd-4fe0-afb7-15096183345a-billede.png" alt="0_1723797835562_6b5a0baf-ccbd-4fe0-afb7-15096183345a-billede.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1723798346655-4f421c83-5eb1-4a83-8f4c-42de312959bb-billede.png" alt="0_1723798346273_4f421c83-5eb1-4a83-8f4c-42de312959bb-billede.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/26797</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26797</guid><dc:creator><![CDATA[Raaskot]]></dc:creator><pubDate>Fri, 16 Aug 2024 08:56:19 GMT</pubDate></item><item><title><![CDATA[Reply to Glitches in Transform tab on Fri, 16 Aug 2024 08:02:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/raaskot" aria-label="Profile: Raaskot">@<bdi>Raaskot</bdi></a></p>
<blockquote>
<p dir="auto">values manipulation either doesn't apply or applies distorted to object.</p>
</blockquote>
<p dir="auto">Not clear what is the issue.<br />
All I can see from the recording that the width or horizontal scale values are changed and the proportional option seems to be on.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26796</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26796</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 16 Aug 2024 08:02:32 GMT</pubDate></item></channel></rss>
