<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mouse Wheel variable scroll rate]]></title><description><![CDATA[<p dir="auto">It's hard to explain, but I recorded audio so you could hear the mouse wheel. It takes several rotations to increment the numeric field for the <strong>Transform</strong> <strong>panel</strong>, for example. It's laborious and certainly easier to just input the values directly. The <strong>Stroke panel</strong> on the other hand is responsive to every click-turn of the wheel. However other fields are behaving like the Transform panel:</p>
<p dir="auto"><a href="https://1drv.ms/u/s!AuWHX0h5bAoRipgO4-SSTtYD25rWxg?e=C1dkBg" rel="nofollow ugc">https://1drv.ms/u/s!AuWHX0h5bAoRipgO4-SSTtYD25rWxg?e=C1dkBg</a></p>
<p dir="auto">There's also another minor issue that isn't worth starting a new thread over, but was found when capturing video for this. Basically, if I select/activate a field for keyboard input, it isn't deactivated when clicking outside of it inside the panel. It's even possible to use the scroll wheel on other fields while other fields are open for input. It should disable input on the other field while with others so that the user 1) knows for sure what the interface expects to respond to (ie they didn't select wrong) 2) it keeps the user focused on one task at a time and finally 3) makes the interface feel more polished</p>
<p dir="auto"><a href="https://1drv.ms/u/s!AuWHX0h5bAoRipgN-atZbP54TYYNJg?e=qJa6uH" rel="nofollow ugc">https://1drv.ms/u/s!AuWHX0h5bAoRipgN-atZbP54TYYNJg?e=qJa6uH</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4590/mouse-wheel-variable-scroll-rate</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 09:01:11 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4590.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Aug 2024 00:54:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mouse Wheel variable scroll rate on Sun, 18 Aug 2024 19:59:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a><br />
<a href="https://www.vectorstyler.com/forum/topic/3021/alt-scroll-wheel-creates-new-obcjects-while-changing-width-height-value-in-transform-panel/3">https://www.vectorstyler.com/forum/topic/3021/alt-scroll-wheel-creates-new-obcjects-while-changing-width-height-value-in-transform-panel/3</a><br />
<a href="https://www.vectorstyler.com/forum/topic/1442/unpredictable-changing-the-value-by-dragging">https://www.vectorstyler.com/forum/topic/1442/unpredictable-changing-the-value-by-dragging</a></p>
<p dir="auto">Hi. I understand what you mean. I have mentioned similar problems in the past.  And in fact I am still experiencing them, but I have acccpeted them.<br />
It's just that each wheel on the mouse has this noticeable click.  And this single click works like a single press of the arrow key.  In VS, when scrolling through the project window, the mouse always reacts in the same way by moving it by a fixed specified value, but with number fields it is different - every few times the wheel has to make 2 such clicks to change the value. As if the application is doing the calculations and the rest from the calculations accumulate . I would like the wheel click to act like a button click,  just like in other apps.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26828</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26828</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Sun, 18 Aug 2024 19:59:56 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Wheel variable scroll rate on Sun, 18 Aug 2024 16:16:20 GMT]]></title><description><![CDATA[<p dir="auto">I just realized my mainroom build might be better for testing. It's still a 4K display (it's on a television), but it has reasonable hardware and even better, it's basically a very clean install of Windows 10. I don't use it for much except games and occasionally test hardware. It has the Pro version, so I can even remote into it to check a file... I'll check that soon.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26827</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26827</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Sun, 18 Aug 2024 16:16:20 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Wheel variable scroll rate on Sun, 18 Aug 2024 06:07:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/26823">Mouse Wheel variable scroll rate</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> said in <a href="/forum/post/26821">Mouse Wheel variable scroll rate</a>:</p>
<blockquote>
<p dir="auto">is that supposed to be the increment/decrement rate or the amount of turn/clicks necessary of scrollwheel to register a change.</p>
</blockquote>
<p dir="auto">These two are related since the number is displayed with limited precision.</p>
</blockquote>
<p dir="auto">I did check the precision to see if it was affecting a change. I even typed in something manually to see if it would show higher precision. It was showing the correct value as far as I can tell, nothing was being rounded.</p>
<blockquote>
<p dir="auto">I tested this on Windows, and here, in the transform panel I need only one click of rotation to change the number by "1".<br />
It might be that there is some mouse settings affecting the speed of change in the system (Windows -&gt; Mouse Settings).</p>
</blockquote>
<p dir="auto">I've definitely not slowed down the scroll speed, if anything I would've sped it up lol. I did disable some things on my Logitech mouse after checking with a non-Logitech mouse to see if it was related to the mouse itself, but it was still the same issue. I can try on one of my other systems later on to see the result in behavior.</p>
<p dir="auto">On this machine, I adjusted this panel, including changing from "pages" to "whole screen" scrolling behavior, and it didn't change how VS received input:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1723960941978-2e4c47e2-4c87-477d-ae42-d0c3af91b0e3-image.png" alt="0_1723960941310_2e4c47e2-4c87-477d-ae42-d0c3af91b0e3-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1723960971701-add0b829-6ced-42a5-8fba-993365435166-image-resized.png" alt="0_1723960971095_add0b829-6ced-42a5-8fba-993365435166-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1723961013144-4a4f6c87-8327-4d61-9c8b-e08d94e6839b-image-resized.png" alt="0_1723961012675_4a4f6c87-8327-4d61-9c8b-e08d94e6839b-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I tested with another mouse (wired, non-Logitech) also, same result. I don't know what it is about my system that makes it so unique for receiving input.</p>
<blockquote>
<p dir="auto">I will try to improve this, but the rate (amount) of change is received by the app is determined by Windows.</p>
</blockquote>
<p dir="auto">I can't think of any point in my history in using Windows where I would've needed to adjust scroll page speed, etc, outside of the web browser. And even then I would mostly use settings like "Smooth scrolling" before having to micromanage anything. It's always "just worked".</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26825</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26825</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Sun, 18 Aug 2024 06:07:52 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Wheel variable scroll rate on Sun, 18 Aug 2024 05:47:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> In VevtorStyler -&gt; Settings -&gt; Number Editors, there is a Number Scrolling Speed. What is the current value there? Try changing it to larger.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26824</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26824</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 18 Aug 2024 05:47:39 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Wheel variable scroll rate on Sun, 18 Aug 2024 05:45:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> said in <a href="/forum/post/26821">Mouse Wheel variable scroll rate</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://www.vectorstyler.com/forum/post/26823</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26823</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 18 Aug 2024 05:45:30 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Wheel variable scroll rate on Sat, 17 Aug 2024 22:55:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> For "change rate", is that supposed to be the increment/decrement rate or the amount of turn/clicks necessary of scrollwheel to register a change. The latter is what I'm reporting the issue one.</p>
<p dir="auto">I included sound to show that it takes 3-4 scrollwheel "clicks" to register a shift in the number, thus it's requiring excessive scrolling to even move the numbers "a little bit" (a little bit = a few increments. It's not referring to the actual amount that is being incremented/decremented.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26821</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26821</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Sat, 17 Aug 2024 22:55:16 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Wheel variable scroll rate on Sat, 17 Aug 2024 05:39:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> I will try to improve this. But yes, different number editor fields can configure their own change rate from the mouse wheel.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26809</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26809</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 17 Aug 2024 05:39:01 GMT</pubDate></item></channel></rss>
