<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Node scaling not working&#x2F;intermittent]]></title><description><![CDATA[<p dir="auto">Basically, I noted the scaling option isn't working for nodes in <strong>Preferences&gt;Path Editing&gt;[Editor Node Scaling]</strong> It's hard to work with nodes in the "default" size on a 4K screen. I imagine VS is meant to use the OS scaling. I have to wonder if it's not even recognizing this setting, because the Preferences override isn't working either. Just a consideration.</p>
<p dir="auto">Evidence for the Court:<br />
<a href="https://1drv.ms/u/s!AuWHX0h5bAoRiptp9d_OSX7v1qOXcQ?e=6Q587F" rel="nofollow ugc">https://1drv.ms/u/s!AuWHX0h5bAoRiptp9d_OSX7v1qOXcQ?e=6Q587F</a></p>
<p dir="auto">In the beginning of the video I simply open up the Preferences and accept the value I had originally set (125%) and it shows up again in the interface correctly (I would imagine). Then I raise it so that we can see clearly it drops back down to 100% after a bit.</p>
<p dir="auto">*Note The bounding box nodes are huge. Nodes however, shrink back down to what seems to be natural 100% scale after being unfocused a bit.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4613/node-scaling-not-working-intermittent</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 23:42:04 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4613.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Sep 2024 04:23:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Sun, 15 Sep 2024 04:19:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Yes, I think that is perfect. Thank you!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27035</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27035</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Sun, 15 Sep 2024 04:19:38 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Fri, 13 Sep 2024 04:54:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> said in <a href="/forum/post/27025">Node scaling not working/intermittent</a>:</p>
<blockquote>
<p dir="auto">In fact, I may need to lower them back down in scale. 100% may be "just right" now.</p>
</blockquote>
<p dir="auto">Now it is also using the display scaling factor from the system settings</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27026</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27026</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 13 Sep 2024 04:54:54 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Thu, 12 Sep 2024 23:00:24 GMT]]></title><description><![CDATA[<p dir="auto">I just opened a document in 1.2.039. Looks like this is fixed! I immediately noticed my nodes are larger. In fact, I may need to lower them back down in scale. 100% may be "just right" now.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27025</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27025</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Thu, 12 Sep 2024 23:00:24 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Sat, 07 Sep 2024 06:45:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> said in <a href="/forum/post/26988">Node scaling not working/intermittent</a>:</p>
<blockquote>
<p dir="auto">When swapping to Anchor Point tool, the points will "rescale" back to the original setting in Preferences (125% in this case). Going back to the Node tool immediately lowers them again</p>
</blockquote>
<p dir="auto">This narrows down a bit the cause, I will try to replicate it.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26990</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26990</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 07 Sep 2024 06:45:56 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Sat, 07 Sep 2024 05:14:57 GMT]]></title><description><![CDATA[<p dir="auto">Another quirk: When swapping to Anchor Point tool, the points will "rescale" back to the original setting in Preferences (125% in this case). Going back to the Node tool immediately lowers them again:</p>
<p dir="auto">Video: <a href="https://1drv.ms/u/s!AuWHX0h5bAoRipw2lfdHHcQAeV0o6w?e=trvgZ6" rel="nofollow ugc">https://1drv.ms/u/s!AuWHX0h5bAoRipw2lfdHHcQAeV0o6w?e=trvgZ6</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/26988</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26988</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Sat, 07 Sep 2024 05:14:57 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Fri, 06 Sep 2024 02:52:39 GMT]]></title><description><![CDATA[<p dir="auto">I noticed that when moving UI-upscaled Nodes, it doesn't change scale immediately. When I run any kind of material operation, like Undo, Join curves, etc, then it causes the nodes to reduce back to the smaller size. It's not preserved though when I restart the program, so I have to go back to Preferences and "resubmit" the larger scale option again. (no change to the field value, just hit OK in <strong>Preferences</strong> on the <strong>Path Editor</strong> page).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26978</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26978</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Fri, 06 Sep 2024 02:52:39 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Tue, 03 Sep 2024 04:59:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> Got it, I will try to replicate this.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26949</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26949</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 03 Sep 2024 04:59:43 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Tue, 03 Sep 2024 04:41:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> No, it was still set at 125% where I had left it a while ago to try. I only noticed it wasn't taking when I had issues accessing nodes and control points (as I typically do at this scale).</p>
<p dir="auto">WP files:<br />
<a href="https://1drv.ms/u/s!AuWHX0h5bAoRiptsp_pr-kuekYgxzw?e=Gfd9W4" rel="nofollow ugc">https://1drv.ms/u/s!AuWHX0h5bAoRiptsp_pr-kuekYgxzw?e=Gfd9W4</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/26946</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26946</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Tue, 03 Sep 2024 04:41:43 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Tue, 03 Sep 2024 04:39:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> Got to the workspace files folder (Help -&gt; Reveal Workspace Folder) and send me those files by email (contains settings and workspace info).</p>
<p dir="auto">I can check if the setting was saved correctly, and if there might be something else interfering with it.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26944</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26944</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 03 Sep 2024 04:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to Node scaling not working&#x2F;intermittent on Tue, 03 Sep 2024 04:29:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a> I could not replicate this using similar steps.</p>
<p dir="auto">When the node sizes return to small, does the setting value also show 100% ?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26942</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26942</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 03 Sep 2024 04:29:40 GMT</pubDate></item></channel></rss>
