<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Could the offset path panel be unlocked to be able to move around the screen?]]></title><description><![CDATA[<p dir="auto">Could the offset path panel be unlocked to be able to move around the screen while in use?<br />
Right now, when I open the Offset Path panel, it appears on the screen and I have to adjust the shapes below to be out of the way of the panel itself. I'd love to be able to drag the panel to the side while it's in use</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1725403373171-119bcfd3-3e3a-46ed-b56f-c6e3bca57fe4-bld-2024-09-03-at-18.41.48.png" alt="0_1725403372162_119bcfd3-3e3a-46ed-b56f-c6e3bca57fe4-BLD 2024-09-03 at 18.41.48.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4616/could-the-offset-path-panel-be-unlocked-to-be-able-to-move-around-the-screen</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 08:27:51 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4616.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Sep 2024 22:44:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Could the offset path panel be unlocked to be able to move around the screen? on Sun, 08 Sep 2024 19:39:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> There seems to be a regression here. The problem was identified and the fix will be in the next build.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26997</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26997</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 08 Sep 2024 19:39:03 GMT</pubDate></item><item><title><![CDATA[Reply to Could the offset path panel be unlocked to be able to move around the screen? on Wed, 04 Sep 2024 16:04:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/26960">Could the offset path panel be unlocked to be able to move around the screen?</a>:</p>
<blockquote>
<p dir="auto">It can be moved around the screen, but the document cannot be accessed in the background.<br />
I think what is needed here is that this view should behave like a panel.</p>
</blockquote>
<p dir="auto">Yes, this is what I was hoping for with the Offset Path panel; that it can be moved around so the selection on the artboard can be seen without having to wonder where the offset path panel will show up and potentially obscure the selection below.<br />
I understand that the selection itself would not be accessible.<br />
thanks for adding it to the list!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26966</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26966</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 04 Sep 2024 16:04:46 GMT</pubDate></item><item><title><![CDATA[Reply to Could the offset path panel be unlocked to be able to move around the screen? on Wed, 04 Sep 2024 07:03:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> It can be moved around the screen, but the document cannot be accessed in the background.</p>
<p dir="auto">I think what is needed here is that this view should behave like a panel.</p>
<p dir="auto">I will add this to the backlog, but only for 1.3 (would be a bit different feature).</p>
<p dir="auto">The non-destructive offset path effect can be added and adjusted from the Shape Effect panel, but that is a bit different.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26960</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26960</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 04 Sep 2024 07:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to Could the offset path panel be unlocked to be able to move around the screen? on Wed, 04 Sep 2024 06:14:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a></p>
<p dir="auto">How about using the "Shape Effect Panel" ?<br />
This is movable</p>
<p dir="auto">Panels &gt; Effects &gt; Shape Effects<br />
then select the "Offset Path Effect"<br />
Outline &gt; Offset Path</p>
<p dir="auto"><a href="https://go.screenpal.com/watch/cZQf1IVRuFL" rel="nofollow ugc">here a video</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/26959</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26959</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Wed, 04 Sep 2024 06:14:14 GMT</pubDate></item><item><title><![CDATA[Reply to Could the offset path panel be unlocked to be able to move around the screen? on Wed, 04 Sep 2024 04:03:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> Ctrl + Mouse Wheel, the screen moves up and down. Ctrl + Shift + Mouse Wheel, the screen moves left and right.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26958</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26958</guid><dc:creator><![CDATA[monsterfox]]></dc:creator><pubDate>Wed, 04 Sep 2024 04:03:02 GMT</pubDate></item></channel></rss>
