<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using the Extend Path tool to adjust a blend]]></title><description><![CDATA[<p dir="auto">Using the Extend Path tool to adjust a blend.</p>
<p dir="auto">This tip can be useful in cases of a blend where you<br />
need to extend the start or end stroke a bit.</p>
<p dir="auto">The idea of ​​using the Extend Path tool for this came to<br />
me when I was doing this shape fill. (Pic below)</p>
<p dir="auto">To do this, I removed parts of the shape and created<br />
a blend between the remaining lines, as this allows<br />
the lines to follow the shape better.</p>
<p dir="auto">This left gaps at the edges where the lines had to be adjusted.<br />
Instead of correcting the line by hand, which may distract the<br />
flow of the Strokes, i tried using the "Extend Path" Tool.<br />
Because this tool is designed to extend a line and works<br />
wonderfully for that purpose.</p>
<p dir="auto"><a href="https://go.screenpal.com/watch/cZQXi9VR7l5" rel="nofollow ugc">Here the Video how i made this fill</a></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1726041859469-blend-fill.png" alt="0_1726041738490_Blend-fill.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4624/using-the-extend-path-tool-to-adjust-a-blend</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 09:50:21 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4624.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Sep 2024 08:05:03 GMT</pubDate><ttl>60</ttl></channel></rss>
