<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.026 RC3]]></title><description><![CDATA[<h3>VectorStyler 1.0.026 RC3 release notes</h3>
<li>Improved: bidirectional and right to left paragraph formatting.</li>
<li>Improved: select text frame column direction.</li>
<li>Improved: automatic insertion of extenders for kashidas.</li>
<li>Improved: extender scaling option in character options.</li>
<li>Improved: character map based glyph scaling for stretching.</li>
<li>Improved: drag&amp;drop color palette into the application window to open it.</li>
<li>Improved: minor UI improvements.</li>
<li>Fixed: select behind with <em>Option</em> (<em>Alt</em>) key did not work.</li>
<li>Fixed: line spacing issues in paragraph composer.</li>
<li>Fixed: wrong default spacing values for justified paragraph stretching.</li>
<li>Fixed: ruler right click on windows did not update the menu.</li>
<li>Fixed: working with multiple documents on windows may slow down some refresh.</li>
<li>Fixed: shortcut for Preferences on Windows did not work.</li>
<li>Fixed: using both ruby and warichu in a paragraph broke the warichu line count.</li>
<li>Fixed: Japanese input method to using space for conversion.</li>
<li>Fixed: shortcut labeling on Windows to use the plus sign.</li>
<li>Fixed: freeze when using text wrap on Windows.</li>
<li>Fixed: control click on ruler to open units menu.</li>
<li>Fixed: cannot interact with document editor after some operations.</li>
<li>Fixed: guideline added under the ruler when clicked.</li>
<li>Fixed: problems with user palette opening button in palette panel.</li>
<li>Fixed: right click on color buttons in color panel to work as alternate selection.</li>
<li>Fixed: set default color with right click.</li>
<li>Fixed: opening ASE color palette files without group headings.</li>
<li>Fixed: opening CSV color palette files.</li>
<li>Fixed: deselect color palette item if current object selection has different colors.</li>
<li>Fixed: editable color tint for tinted color palette items.</li>
<li>Fixed: close path for some boolean operations (union, merge, boundary).</li>
<li>Fixed: positioning of negative flipped characters to set normal (absolute) space.</li>
<li>Fixed: select node of gradient mesh when creating a new mesh with the mesh editor tool.</li>
<li>Fixed: boundary path operation did not undo (and hovering preview did not work correctly).</li>
<li>Fixed: moving quadratic curves did not move the anchor point in some cases.</li>
<li>Fixed: color mixer image filter layout was broken.</li>
<li>Fixed: global snapping options mode blocked the snapping panel changes.</li>
<li>Fixed: preview check box place in layer and object options view.</li>
<li>Fixed: tool tips in the toolbox did not show the active tool description.</li>
<li>Fixed: automatic preview in the text wrap view if preview is enabled.</li>
<li>Fixed: undoing the text wrap options did not reset the text frames.</li>
<li>Fixed: additional options for the boundary path operation, available in the Path panel menu.</li>
<li>Fixed: repeat last to use object rotation center.</li>
<li>Fixed: scrolling of layer (and other) lists when dragging items.</li>
<li>Fixed: pen tool option in Preferences to allow filled shape creation.</li>
<li>Fixed: selecting and editing path shapes inside a hierarchy of transformed groups.</li>
<li>Fixed: export again to also open the file if enabled.</li>
<li>Fixed: inserting symbols from presets into text did not work.</li>
<li>Fixed: pasting multiple objects could not be undone correctly.</li>
<li>Fixed: exporting transparent image into PDF breaks the transparency of objects above the image.</li>
<li>Fixed: zero width spaces and joiners were not zero width.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/475/update-1-0-026-rc3</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:12 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/475.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 May 2021 18:50:39 GMT</pubDate><ttl>60</ttl></channel></rss>
