<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;-&quot; (minus) key to delete nodes inserted with the &quot;+&quot; key ?]]></title><description><![CDATA[<p dir="auto">We can inserte Nodes on to a shape via pressing the " + " Key<br />
but it seems there is no such way to delete such inserted Nodes.</p>
<p dir="auto">I thought of mine was how about using the " - " (minus) key<br />
for that or any other way ?</p>
<p dir="auto">See this Post here<br />
<a href="https://www.vectorstyler.com/forum/topic/4854/node-tool-drag-select-short-key-how-do-i-select-and-activate-every-nodes-in-same-shape/7">https://www.vectorstyler.com/forum/topic/4854/node-tool-drag-select-short-key-how-do-i-select-and-activate-every-nodes-in-same-shape/7</a></p>
<p dir="auto">Well, I have to say that I'm not sure if this is actually a good idea<br />
but I just wanted to post it</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4856/minus-key-to-delete-nodes-inserted-with-the-key</link><generator>RSS for Node</generator><lastBuildDate>Thu, 05 Mar 2026 07:52:02 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4856.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Dec 2024 11:02:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;-&quot; (minus) key to delete nodes inserted with the &quot;+&quot; key ? on Fri, 13 Dec 2024 15:30:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">i know i can delete using the Delete key<br />
but only for newly inserted Nodes</p>
<p dir="auto">i was talking about reverse these Steps (delete the Nodes)<br />
in the direction there was inserted</p>
<p dir="auto"><a href="https://go.screenpal.com/watch/cZlIoqnn52z" rel="nofollow ugc">Here a video about it</a><br />
.<br />
.<br />
But I would say forget about this suggestion for now,<br />
this may be perhaps a too special case</p>
<p dir="auto">It is a bit more complicated but in the end you can select<br />
the nodes you want to delete.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28267</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28267</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 13 Dec 2024 15:30:59 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;-&quot; (minus) key to delete nodes inserted with the &quot;+&quot; key ? on Fri, 13 Dec 2024 13:28:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> You can delete with the "delete" key.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28263</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28263</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 13 Dec 2024 13:28:34 GMT</pubDate></item></channel></rss>
