<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Opening the &quot;Color&quot; panel in any way crashes the program]]></title><description><![CDATA[<p dir="auto">I'm running v1.2.054 on windows 10.</p>
<p dir="auto">Attempting to open the Color panel by clicking on it on the UI, selecting it on the Panels menu or double clicking the color picker on a selected object's stroke or fill, immediately crashes the program. This makes vectorstyler completely unusable to me at the moment. <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f635.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--dizzy_face" style="height:23px;width:auto;vertical-align:middle" title=":dizzy_face:" alt="😵" /></p>
<p dir="auto">This happens regardless of the file that has been loaded and in fact happens even if no file is open at all.</p>
<p dir="auto">This is the latest generated crash dump from me clicking the color tab on the user interface with no file loaded.</p>
<p dir="auto">The crash dump is too large to post here, so I have uploaded it to my personal file share.<br />
<a href="https://files.loginerror.net/share/jKgXEWv_" rel="nofollow ugc">https://files.loginerror.net/share/jKgXEWv_</a><br />
Please let me know when you have downloaded it so I can remove it.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4899/opening-the-color-panel-in-any-way-crashes-the-program</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 03:03:08 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4899.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jan 2025 02:20:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Opening the &quot;Color&quot; panel in any way crashes the program on Fri, 10 Jan 2025 02:06:19 GMT]]></title><description><![CDATA[<p dir="auto">Setting compute engine to "Software" seems to fix it. Thanks.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28474</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28474</guid><dc:creator><![CDATA[LoginError]]></dc:creator><pubDate>Fri, 10 Jan 2025 02:06:19 GMT</pubDate></item><item><title><![CDATA[Reply to Opening the &quot;Color&quot; panel in any way crashes the program on Thu, 09 Jan 2025 00:10:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/loginerror" aria-label="Profile: LoginError">@<bdi>LoginError</bdi></a> Try setting the compute engine to "Software" in settings.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28467</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28467</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 09 Jan 2025 00:10:02 GMT</pubDate></item><item><title><![CDATA[Reply to Opening the &quot;Color&quot; panel in any way crashes the program on Wed, 08 Jan 2025 23:00:42 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the fix!</p>
<p dir="auto">Is it possible to change the color mode for the panel without opening the panel? I'd rather not have to rebuild my entire workspace from scratch if I can avoid it.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28466</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28466</guid><dc:creator><![CDATA[LoginError]]></dc:creator><pubDate>Wed, 08 Jan 2025 23:00:42 GMT</pubDate></item><item><title><![CDATA[Reply to Opening the &quot;Color&quot; panel in any way crashes the program on Wed, 08 Jan 2025 08:49:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/loginerror" aria-label="Profile: LoginError">@<bdi>LoginError</bdi></a> And the root cause was identified. Using HSL for color spectrum causes the crash. As a temporary workaround, use an other color mode for the color panel spectrum image.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28455</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28455</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 08 Jan 2025 08:49:59 GMT</pubDate></item><item><title><![CDATA[Reply to Opening the &quot;Color&quot; panel in any way crashes the program on Wed, 08 Jan 2025 08:43:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/loginerror" aria-label="Profile: LoginError">@<bdi>LoginError</bdi></a> Thanks! This helps a lot, I have been able to replicate the crash.<br />
I will try to fix this for the next build.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28454</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28454</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 08 Jan 2025 08:43:42 GMT</pubDate></item><item><title><![CDATA[Reply to Opening the &quot;Color&quot; panel in any way crashes the program on Wed, 08 Jan 2025 04:41:37 GMT]]></title><description><![CDATA[<p dir="auto">I found the data directory in<br />
C:\Users&lt;username&gt;\AppData\Local\NumericPath\VectorStyler1.2\vector\data<br />
rather than in AppData\Roaming</p>
<p dir="auto">After backing up and deleting the settings directory, the program launched and worked properly without crashing while editing colors, of course without my workspace customizations.</p>
<p dir="auto">Restoring the settings directory brought back the crashes, so the cause is clearly something in my customization. I have not made any notable changes to my workspace or settings since last successfully using the program. The last thing I used it for was creating the proof of concept file for the overlapping artboard texture bug I posted earlier.</p>
<p dir="auto">I also screen captured the program crashing. This screen capture didn't capture the mouse, so I will describe what I did in each of the crashes.</p>
<ol>
<li>Opened the program, created a new file, clicked on the color tab on the center right of the screen.</li>
<li>Opened the program, created a new file, drew a line, clicked on the color square of the stroke on the upper right on the Appearence panel.</li>
<li>Opened the program, clicked on the color tab on the center right of the screen.</li>
<li>Opened the program, selected the color panel from the Panels dropdown menu.</li>
</ol>
<p dir="auto">The files can be found here:<br />
<a href="https://files.loginerror.net/share/Rdet3rL5" rel="nofollow ugc">https://files.loginerror.net/share/Rdet3rL5</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/28453</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28453</guid><dc:creator><![CDATA[LoginError]]></dc:creator><pubDate>Wed, 08 Jan 2025 04:41:37 GMT</pubDate></item><item><title><![CDATA[Reply to Opening the &quot;Color&quot; panel in any way crashes the program on Tue, 07 Jan 2025 07:26:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/loginerror" aria-label="Profile: LoginError">@<bdi>LoginError</bdi></a> I downloaded the file.<br />
Can you send me a recording on how this happens? (double clicking the color picker on a selected object's stroke or fill).</p>
<p dir="auto">When you start the app, it should send a crash log, I will try to find that.</p>
<p dir="auto">Meanwhile, go to the workspace / settings file folder, backup all these and send them to me and then remove them.</p>
<p dir="auto">On Windows these files are in the c:\Users&lt;user name&gt;\AppData\Roaming\NumericPath\VectorStyler1.2\vector\data\resources\ folder</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28452</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28452</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 07 Jan 2025 07:26:12 GMT</pubDate></item></channel></rss>
