<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[beta build 139]]></title><description><![CDATA[<p dir="auto">Fixed some major regressions and bugs.</p>
<h3>VectorStyler beta 139 release notes</h3>
<li>Fixed: importing progressive jpeg images with reduced chroma channels.</li>
<li>Fixed: importing CMYK jpeg.</li>
<li>Fixed: set artboard size and center image when opening an image as a document.</li>
<li>Fixed: stroke expand with calligraphic stroke options.</li>
<li>Fixed: short brush sweeps with calligraphic tip were broken.</li>
<li>Fixed: importing linked content from AI files.</li>
<li>Added: show isolated object path at the top of the view.</li>
<li>Added: isolate layer in Layers panel using control+click.</li>
<li>Added: show glyph alternate popup in text editor, when available.</li>
<li>Added: text frame flow handles in the basic transform tool.</li>
<li>Added: paste object as a glyph inside text.</li>
<li>Added: swap fill and stroke styles using shift+X.</li>
<li>Added: swap fill mode (fill or stroke) using the key X.</li>
<li>Added: can also rotate document view using shift+spacebar.</li>
<li>Added: lorem ipsum for new text.</li>
<li>Added: scale content of text frames when using the scale tool.</li>
<li>Changed: use Esc key to exit from isolation mode, deselect is now shift+command+a.</li>
<li>Fixed: very long single paragraph text can become slow to set.</li>
<li>Fixed: keep the color mode when add colors from the document to the palette.</li>
<li>Added: set color mode for multiple selected colors from the color palette panel menu.</li>
<li>Added: preview color when selecting color from the modal view.</li>
<li>Added: corner editor tool to localize corner if handle is clicked.</li>
<li>Added: SVG import to create layers of groupmode is a layer.</li>
<li>Fixed: linear (axial) gradient editor color handles were inverted.</li>
<li>Fixed: font list to restart search from the beginning when typing font name.</li>
<li>Added: inner radius and shifting amounts for star shapes can be edited numerically.</li>
<li>Fixed: crash when rendering certain documents with images.</li>
<li>Fixed: occasional crash when refreshing documents.</li>
<li>Fixed: force quit needed when very complex shapes are touched with the stroke profile width tool.</li>
<li>Fixed: a regression when importing certain GIF image types.</li>
<li>Fixed: a regression on adding guidelines from the ruler.</li>
<h3>Bug fixes in recent releases</h3>
<li>Fixed: crash at startup caused by storing the recent actions preset.</li>
<li>Fixed: path drawing tool uses Option key for cusp corner tool.</li>
<li>Fixed: retain transformations when coping and pasting objects from inside transformed groups.</li>
<li>Fixed: corner size painter tool to adjust sizes locally.</li>
<li>Added: use space bar to move last node in path drawing tool.</li>
<li>Changed: path drawing actions are not recorded.</li>
<li>Added: use Command+Spacebar to zoom.</li>
<li>Fixed: regression bug causing the loss of docked panels after exit.</li>
<li>Fixed: crash when importing some PS files.</li>
<li>Fixed: crash in user interface.</li>
<li>Fixed: numerous shape builder fixes regarding complex shapes.</li>
<li>Fixed: shape builder performance on complex shapes.</li>
<li>Fixed: eraser tool with complex shapes.</li>
<li>Fixed: shape boolean operations on complex shapes.</li>
<li>Fixed: document changes with eraser tool and filter brush tools were not marked.</li>
<li>Fixed: bug in importing PNG files.</li>
<li>Fixed: bug in importing AI files with linked content.</li>
<li>Fixed: bug in importing text frames from AI.</li>
<li>Fixed: after command hold while editing text will restore text selection.</li>
<li>Fixed: to use current file name in the Save As view.</li>
<li>Improved: context panel updating when document is closed.</li>
<li>Changed: path editing tools were moved into a group withj the corner tool.</li>
<li>Changed: eraser tool to pain erased area first and erase the shape only at mouse release.</li>
<li>Changed: path simplify tool paints over area first.</li>
<li>Added: preview checkbox to the Simplify Path command.</li>
<li>Added: jump to font names when typing in font name selector.</li>
<li>Added: interactive path node eraser tool.</li>
<li>Added: interactive corner size adjustment tool.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/50/beta-build-139</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:56:32 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/50.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Apr 2020 16:51:40 GMT</pubDate><ttl>60</ttl></channel></rss>
