<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Possible Error in Properties Panel Transform &gt; Scale]]></title><description><![CDATA[<p dir="auto">Hello Mr. VectorStyler,<br />
Amazing piece of software!! Thank you very much for your impressive work!</p>
<p dir="auto">Not sure if it is a bug, but hopefully better reported:<br />
In the Properties Panel under the Transform-Section after Flipping an Object the Scale-Values change to "0,1%" . If you flip again in the other direction (e.g. vertical after horizontal) the "0,1" changes back to "100%" while the new scale value now reads "0.1%". When you enter "-100%" directly via the Input-Field it also changes to "0,1%" and "flat"-scales the object accordingly. Maybe I misinterpret this "Scale"-fields and their meaning?<br />
In the Transform-Panel it reads "-100%" as I would expect.</p>
<p dir="auto">Hope that helps. All the best!<br />
w.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5258/possible-error-in-properties-panel-transform-scale</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 13:07:06 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5258.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Jul 2025 22:51:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Possible Error in Properties Panel Transform &gt; Scale on Fri, 04 Jul 2025 06:24:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/wolfgang" aria-label="Profile: Wolfgang">@<bdi>Wolfgang</bdi></a> Yes, this seems to be an error, the field has the wrong lower limit. The Transform panel should display the correct scale. This will be fixed in the next build</p>
]]></description><link>https://www.vectorstyler.com/forum/post/30512</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/30512</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 04 Jul 2025 06:24:20 GMT</pubDate></item></channel></rss>
