<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.030 RC3]]></title><description><![CDATA[<h3>VectorStyler 1.0.030 RC3 release notes</h3>
<li>Fixed: selecting and changing control points.</li>
<li>Fixed: selecting nodes of overlapped paths.</li>
<li>Fixed: do not select another shape when starting a node selection using the box marque.</li>
<li>Fixed: do not show all nodes of selected shape types.</li>
<li>Fixed: inserting new nodes at multiple selected inner nodes.</li>
<li>Fixed: using line or open path exclude to cut composite paths.</li>
<li>Fixed: positioning of some image effects when used as adjustment layer.</li>
<li>Fixed: undoing shape duplication around blend objects did not refresh.</li>
<li>Fixed: use return key to confirm blend creation from the blend panel.</li>
<li>Fixed: corner editor tool may adjust wrong corner in some cases.</li>
<li>Fixed: use larger than 0 default stroke width of no width selection occurred before.</li>
<li>Fixed: random scatter and bristle brush seed adjustment from the brush style panel.</li>
<li>Fixed: show null color when set without an object selection.</li>
<li>Fixed: handling of hidden objects.</li>
<li>Fixed: undoing the hidden attribute did not refresh.</li>
<li>Fixed: default color of some node handles.</li>
<li>Fixed: UI style adjustments.</li>
<li>Fixed: do not show highlight when hovering in toolbox.</li>
<li>Fixed: highlighting in vertical text with roman rotation.</li>
<li>Fixed: text frame content did not refresh in some cases.</li>
<li>Fixed: highlight can be wrong with flipped characters.</li>
<li>Fixed: edit color harmony groups from the color palette panel.</li>
<li>Fixed: spot colors were expanded when applied to selection.</li>
<li>Fixed: pasting objects with contour effect may hang.</li>
<li>Fixed: do not scroll when using the sketch tool.</li>
<li>Fixed: allow original path deletion in the Offset Path change.</li>
<li>Fixed: larger default size of the shape and image effects view.</li>
<li>Fixed: adjustable tool tip delay in preferences.</li>
<li>Fixed: in layers panel, dragging objects over the delete icon should be indicated.</li>
<li>Fixed: could not select objects in layers panel immediately after dragging over selection.</li>
<li>Fixed: adjustable cursor size in preferences.</li>
<li>Fixed: replacing all text may hang.</li>
<li>Fixed: removing multiple nodes in a shape may result in wrong smooth nodes.</li>
<li>Fixed: opening fill popover should default to a content suitable for the current fill.</li>
<li>Fixed: title icon of the color palette bar should be direction dependent.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/527/update-1-0-030-rc3</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:28:17 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/527.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 May 2021 19:30:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.0.030 RC3 on Mon, 31 May 2021 20:36:38 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin All fixes and no new add-ons - probably a sign we're getting closer to final release? Not that I'm in a rush personally. I'm enjoying following along the process of getting the app ready for final release</p>
]]></description><link>https://www.vectorstyler.com/forum/post/2420</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/2420</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 31 May 2021 20:36:38 GMT</pubDate></item></channel></rss>
