<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Transform pivot point regression]]></title><description><![CDATA[<p dir="auto">When I set the transform pivot point for a full 360 degree rotation and try to duplicate copies using Shift+Alt keys, VS is failing to follow the desired set rotation.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5325/transform-pivot-point-regression</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 07:35:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5325.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Aug 2025 21:22:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Transform pivot point regression on Tue, 26 Aug 2025 23:29:56 GMT]]></title><description><![CDATA[<p dir="auto">This issue has been resolved in the latest update.  Thank you!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/30839</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/30839</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Tue, 26 Aug 2025 23:29:56 GMT</pubDate></item><item><title><![CDATA[Reply to Transform pivot point regression on Sat, 23 Aug 2025 21:15:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/30815">Transform pivot point regression</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> A recording is needed for this one. Did you rotate with the Transform panel, or with the transform tool?</p>
</blockquote>
<p dir="auto">I used the Transform toòl and Control+D.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/30819</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/30819</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Sat, 23 Aug 2025 21:15:21 GMT</pubDate></item><item><title><![CDATA[Reply to Transform pivot point regression on Sat, 23 Aug 2025 05:57:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> A recording is needed for this one. Did you rotate with the Transform panel, or with the transform tool?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/30815</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/30815</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 23 Aug 2025 05:57:36 GMT</pubDate></item></channel></rss>
