<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.038]]></title><description><![CDATA[<p dir="auto">There was a regression with the trial mode.</p>
<h3>VectorStyler 1.0.038 release notes</h3>
<li>Improved: cut and merge variable width profiles with the pencil eraser mode.</li>
<li>Fixed: problems with tab positions in frame text.</li>
<li>Fixed: bleed and slug handling.</li>
<li>Fixed: collider tool should work also when the <em>Snap to Shapes</em> is disabled.</li>
<li>Fixed: selecting stroke width in the Properties panel.</li>
<li>Fixed: slider increment should be small when using large units.</li>
<li>Fixed: changing default stroke and brush width from zero.</li>
<li>Fixed: problems with knife tool on composite shapes.</li>
<li>Fixed: pasting to active artbaord in the same document.</li>
<li>Fixed: preview of deleting original option in the <em>Offset Path</em> view.</li>
<li>Fixed: background of context panel in light modes.</li>
<li>Fixed: solid stroke preview in brush panel should be darker.</li>
<li>Fixed: automatic scrolling when hovering over font list margins.</li>
<li>Fixed: scissor tool should convert shapes to curves.</li>
<li>Fixed: node eraser should not remove whole objects when clicking on a shape node.</li>
<li>Fixed: importing gradient from EPS files.</li>
<li>Fixed: cannot change color mode in color panel if nothing is selected.</li>
<li>Fixed: under of color filters on text shape breaks.</li>
<li>Fixed: wrong clipping of image effects on shapes with winding fills.</li>
<li>Fixed: find / replace in some text shapes may crash the app.</li>
<li>Fixed: pasting appearance will paste new objects of objects were copied after appearance (should have separate pasteboard).</li>
<li>Fixed: displaying effects on some shapes with outlines had the wrong effect region.</li>
<li>Fixed: copying objects to the pasteboard clears the selection (and keeps the copy selected).</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/569/update-1-0-038</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:28:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/569.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Jun 2021 15:45:42 GMT</pubDate><ttl>60</ttl></channel></rss>
