<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Copy and Paste don&#x27;t work as expected]]></title><description><![CDATA[<p dir="auto">I am currently working with text objects. I'll do a cut (command C) with a portion of the text, and that seems to work fine. But when I paste (command V) it won't show up. I'll have to go to the Edit&gt;Paste and even that won't always work. Also, I can't seem to get it on the Targeted Layer all the time. The best success I've had on several paste attempts was when I was still on the same layer I was trying to move it from.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/576/copy-and-paste-don-t-work-as-expected</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 04:38:55 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/576.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Jun 2021 10:15:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Copy and Paste don&#x27;t work as expected on Sat, 11 Sep 2021 07:40:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/buckycore" aria-label="Profile: buckycore">@<bdi>buckycore</bdi></a> There have been fixes to the pasteboard in the new build (1.0.048). Let me know if this issue can still be replicated.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3964</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3964</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 11 Sep 2021 07:40:38 GMT</pubDate></item><item><title><![CDATA[Reply to Copy and Paste don&#x27;t work as expected on Wed, 16 Jun 2021 10:36:11 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Now it seems to be working fine. However, I had a linked Image in my original, but in the example, I'm about to send to you I removed it. However, to do the diagnostics correctly, I'd suggest Linking a large Image at 300dpi and see if that's that pertains to the issue.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/2683</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/2683</guid><dc:creator><![CDATA[buckycore]]></dc:creator><pubDate>Wed, 16 Jun 2021 10:36:11 GMT</pubDate></item><item><title><![CDATA[Reply to Copy and Paste don&#x27;t work as expected on Wed, 16 Jun 2021 10:28:32 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Sure. Give me a moment and I will do so (FYI, I use MEGA, but it works the same as DropBox)</p>
]]></description><link>https://www.vectorstyler.com/forum/post/2682</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/2682</guid><dc:creator><![CDATA[buckycore]]></dc:creator><pubDate>Wed, 16 Jun 2021 10:28:32 GMT</pubDate></item><item><title><![CDATA[Reply to Copy and Paste don&#x27;t work as expected on Wed, 16 Jun 2021 10:27:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/buckycore" aria-label="Profile: buckycore">@<bdi>buckycore</bdi></a> If there is a sample document where this copy pasting issue can be replicated, it would help if you could send a link to it (on dropbox), or send it to be by email: csraba at <a href="http://vectorstyler.com" rel="nofollow ugc">vectorstyler.com</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/2681</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/2681</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 16 Jun 2021 10:27:29 GMT</pubDate></item><item><title><![CDATA[Reply to Copy and Paste don&#x27;t work as expected on Wed, 16 Jun 2021 10:22:48 GMT]]></title><description><![CDATA[<p dir="auto">I played with the height and size in the text frame before I did the copy and paste. However, That's all I did as far as formatting as I didn't play with Kerning nor spacing. However, it maybe it's from the font its self? Just a thought. The font is called TOXIA. I'm only using the first/default Font Tool, as it's a graphical font  object I'm experimenting with</p>
]]></description><link>https://www.vectorstyler.com/forum/post/2678</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/2678</guid><dc:creator><![CDATA[buckycore]]></dc:creator><pubDate>Wed, 16 Jun 2021 10:22:48 GMT</pubDate></item><item><title><![CDATA[Reply to Copy and Paste don&#x27;t work as expected on Wed, 16 Jun 2021 10:19:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/buckycore" aria-label="Profile: buckycore">@<bdi>buckycore</bdi></a> Could not replicate this one, after a quick try.<br />
Does the text contain any local formatting (changes in color or character style)?<br />
What tool is selected when pasting?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/2675</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/2675</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 16 Jun 2021 10:19:19 GMT</pubDate></item></channel></rss>
