<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.039]]></title><description><![CDATA[<h3>VectorStyler 1.0.039 release notes</h3>
<li>Fixed: pencil eraser tool should not reduce the width profile to zero.</li>
<li>Fixed: refactor spot color handling UI in printer settings view.</li>
<li>Fixed: selecting a character style in the context panel did not work.</li>
<li>Fixed: cursor reverts to arrow after drawing the first shape.</li>
<li>Fixed: duplicating objects having a contour effect.</li>
<li>Fixed: scrolling with the mouse in numeric fields.</li>
<li>Fixed: ungroup multiple objects in the layers panel.</li>
<li>Fixed: cut self intersecting closed paths with pencil eraser tool.</li>
<li>Fixed: handling self intersections in winding shape normalization.</li>
<li>Fixed: shape builder to work better with self intersecting shapes.</li>
<li>Fixed: single click highlight of numeric fields.</li>
<li>Fixed: add a reset button to the printer settings view.</li>
<li>Fixed: adjust crop mark gap using the marker offset settings.</li>
<li>Fixed: show document bleed and slug values in printer settings view.</li>
<li>Fixed: repeating copy and rotate to use the actual pivot point.</li>
<li>Fixed: paste registers in undo as duplicate.</li>
<li>Fixed: exporting clipped groups into image formats used wrong bounding box.</li>
<li>Fixed: exporting some image effects may fail.</li>
<li>Fixed: combining objects with referenced shapes.</li>
<li>Fixed: ruler in paragraph view to use document units and allow scrolling.</li>
<li>Fixed: update path panel immediately when moving nodes.</li>
<li>Fixed: exporting flipped characters to SVG.</li>
<li>Fixed: SVG bitmap fonts did not render correctly.</li>
<li>Fixed: exporting bitmap fonts to PDF.</li>
<li>Fixed: rotate tool did not detect upper right corner.</li>
<li>Fixed: offset path on text shape did not show original if enabled.</li>
<li>Fixed: with of numeric fields in the properties panel.</li>
<li>Fixed: better layout in navigation panel.</li>
<li>Fixed: merge width profile when erasing from brushes.</li>
<li>Fixed: exporting gradients to SVG files.</li>
<li>Fixed: low zoom levels did not allow moving of small objects.</li>
<li>Fixed: pencil eraser tool may incorrectly remove objects.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/609/update-1-0-039</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:28:12 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/609.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Jun 2021 19:30:03 GMT</pubDate><ttl>60</ttl></channel></rss>
