<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.044]]></title><description><![CDATA[<h3>VectorStyler 1.0.044 release notes</h3>
<li>Improved: WMF/EMF import and export file format support, on Windows and also on Mac.</li>
<li>Improved: left and right arrow keys should also change the corner count of super shapes.</li>
<li>Improved: preferences option to not update the default fill and stroke styles when selecting objects.</li>
<li>Improved: multiple new select similar and select attribute options.</li>
<li>Improved: option to compare only the type of shape (or image) effects when searching by attributes with the find panel.</li>
<li>Improved: show zero width stroke as Hairline.</li>
<li>Improved: rotate view back to zero when double clicking with the view rotate tool.</li>
<li>Improved: straight line mode in the pencil tool by pressing the tab key.</li>
<li>Improved: (color) and style picker mode to just drag and drop styles between objects.</li>
<li>Improved: path brush tool to change only shapes of the current style.</li>
<li>Improved: path brush tool to merge multiple shapes into a single one.</li>
<li>Improved: added new commands to expand clipping groups by intersecting the content with the clipping shape, with or without stroke expansion.</li>
<li>Improved: added new commands to intersect a set of shapes with a single closed shape, with or without stroke expansion.</li>
<li>Improved: allow stroke color and width selection in the (destructive) Offset path view.</li>
<li>Improved: various UI style improvements, including the Stroke panel icons.</li>
<li>Fixed: Apple Silicon compatibility bug fixes.</li>
<li>Fixed: copy and paste vectors (PDF and SVG) to clipboard on Windows.</li>
<li>Fixed: default transform pivot of text shapes should be at the center.</li>
<li>Fixed: align zero length dashes to cusp corners.</li>
<li>Fixed: some imported and clipped images may display in a broken form.</li>
<li>Fixed: file reverting breaks layer panel content list.</li>
<li>Fixed: clipboard change notification handling on Windows.</li>
<li>Fixed: do not change zoom after document setup is confirmed.</li>
<li>Fixed: mirroring should not change the transform pivot point.</li>
<li>Fixed: when objects are placed outside of a top layer, the place above/below is not working.</li>
<li>Fixed: stroke on a path with stray points did not expand.</li>
<li>Fixed: full saturation and brightness for the hue slider in the color panel.</li>
<li>Fixed: copying a path part will break the regular object pasteboard.</li>
<li>Fixed: blend step of 1 should result in a single intermediary shape.</li>
<li>Fixed: some icon labels were missing.</li>
<li>Fixed: print to PDF with Microsoft driver may crash if printing in the background.</li>
<li>Fixed: text highlight should work also when the mouse is outside of the text area.</li>
<li>Fixed: creating an empty folder in the preset manager should work when there is no selection.</li>
<li>Fixed: scrolling in percent field should be smoother.</li>
<li>Fixed: scaling from the transform panel should add a scale on the object instead of just changing the shape size.</li>
<li>Fixed: confirming nudge settings from the context panel should focus the document.</li>
<li>Fixed: navigator panel showing a red square when the document is refreshed.</li>
<li>Fixed: setting the brush offset on a solid stroke will break the stroke.</li>
<li>Fixed: paste below when multiple objects are selected should paste below the bottom object.</li>
<li>Fixed: selecting blend spine should deselect the source shape to allow further blend option changes.</li>
<li>Fixed: do not allow duplicate shortcuts in the shortcut editor.</li>
<li>Fixed: selecting objects in the layers panel did not update the context panel.</li>
<li>Fixed: changes on symbol presets should detach the symbol objects.</li>
<li>Fixed: background issues in the gray theme.</li>
<li>Fixed: All Fonts collection is not updated after font folder scanning completes.</li>
<li>Fixed: pencil tool should also allow fill styles by default.</li>
<li>Fixed: inner glow margins may be broken for some shapes.</li>
<li>Fixed: blurry application icon.</li>
<li>Fixed: changing contextual shortcuts did not work.</li>
<li>Fixed: stroke popover did not apply stroke width.</li>
<li>Fixed: slower scrolling in layers panel when drag&amp;drop hovering.</li>
<li>Fixed: convert to curves inside transformed groups should not include the group transforms in the resulting path.</li>
<li>Fixed: allow isolation by double click in the shape editor.</li>
<li>Fixed: blend tool selection may add an empty undo change.</li>
<li>Fixed: use an upper limit for the blending steps.</li>
<li>Fixed: blend object may be lost when cutting and pasting.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/713/update-1-0-044</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:28:18 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/713.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Aug 2021 05:58:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.0.044 on Mon, 02 Aug 2021 15:31:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> yes, the <em>Select -&gt; Outline -&gt; Variable Width Brushes</em> will select brushes with variable width profiles (tapered included).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3397</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3397</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 02 Aug 2021 15:31:08 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.0.044 on Mon, 02 Aug 2021 14:57:41 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/3337">update 1.0.044</a>:</p>
<blockquote>
<p dir="auto">Improved: multiple new select similar and select attribute options.</p>
</blockquote>
<p dir="auto">Is this related to the taper outlines we spoke about a while back? Being able to expand tapered strokes and then remove the taper guides? If not, it's ok, not rushing you</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3396</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3396</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 02 Aug 2021 14:57:41 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.0.044 on Mon, 02 Aug 2021 14:55:41 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin This is an awesome update! It's obvious a lot of hard work went into this  (and every update)</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3395</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3395</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 02 Aug 2021 14:55:41 GMT</pubDate></item></channel></rss>
