<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.046]]></title><description><![CDATA[<h3>VectorStyler 1.0.046 release notes</h3>
<li>Improved: added option to Character panel menu to always use default character style when creating text objects.</li>
<li>Improved: nudge by 1/10th while holding Shift+Control.</li>
<li>Improved: added an expand button to the Image Trace panel.</li>
<li>Improved: added a solid stroke button in stroke width panel.</li>
<li>Improved: use Option+ (Alt+) key to flip guideline orientation when dragging a new guideline from the ruler.</li>
<li>Fixed: improved offset path and stroke alignment.</li>
<li>Fixed: improved intersection for touching shapes.</li>
<li>Fixed: exclude problem with overlapping margins.</li>
<li>Fixed: remove collinear point sequences in union results.</li>
<li>Fixed: moving objects in some shape and image filter editors.</li>
<li>Fixed: possible crash when closing documents.</li>
<li>Fixed: scaled stroke expansion in filtered outlines.</li>
<li>Fixed: problems with shortcuts when the text editor is active on Windows.</li>
<li>Fixed: font name is wrong after scaling text.</li>
<li>Fixed: style picker handling of isolation modes.</li>
<li>Fixed: regression in composite shape tool.</li>
<li>Fixed: copy and paste vector with image effects on Windows.</li>
<li>Fixed: image effect exporting to PDF.</li>
<li>Fixed: preview of initial segment in pen tool.</li>
<li>Fixed: stroke width using mm as units did not show mm in Appearance panel and width popup.</li>
<li>Fixed: gradient editor leaves the undo broken.</li>
<li>Fixed: changing UI scaling broke the context panel.</li>
<li>Fixed: double clicking a segment in the node editor should not isolate.</li>
<li>Fixed: rotating and then scaling multiple skewed objects created the wrong transform.</li>
<li>Fixed: some popover backgrounds were not rounded on Mac.</li>
<li>Fixed: Shift+ selection in corner tool.</li>
<li>Fixed: triple click line selection highlighted one more character in the next line.</li>
<li>Fixed: do not use Style labels for character and paragraph style drop downs.</li>
<li>Fixed: pattern brush preview should be proportional.</li>
<li>Fixed: tolerance editing in preferences did not show default values.</li>
<li>Fixed: brush style popover in appearance panel had wrong size.</li>
<li>Fixed: brush style panel did not update when swapping fill and stroke styles.</li>
<li>Fixed: font search bar case sensitivity issues.</li>
<li>Fixed: switch from text tool to other tools using shortcuts (when not editing a text).</li>
<li>Fixed: entering and exiting isolated mode in layers panel.</li>
<li>Fixed: selecting blending mode of an empty layer used the blending mode for the objects added to the layer also (cleared with a refresh).</li>
<li>Fixed: transform pivot point should stay fixed when duplicating objects.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/777/update-1-0-046</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:28:17 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/777.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Aug 2021 07:05:05 GMT</pubDate><ttl>60</ttl></channel></rss>
