<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.048]]></title><description><![CDATA[<h3>VectorStyler 1.0.048 release notes</h3>
<li>Improved: preview stroke profile, dash and stripe from modal editors.</li>
<li>Improved: activate lasso tool by holding Option (Alt) key.</li>
<li>Improved: option to show monochrome glyphs in glyph panel.</li>
<li>Improved: use space key to flip side when interactively editing a text on path.</li>
<li>Fixed: decreased UI font size.</li>
<li>Fixed: copy and paste images from any browser.</li>
<li>Fixed: drag and drop images from other apps (including browsers).</li>
<li>Fixed: multiple intersection and union bugs.</li>
<li>Fixed: added splash screen for Windows.</li>
<li>Fixed: bend effect resulting from expanded vector brush has wrong shift.</li>
<li>Fixed: offset path color is not previewed.</li>
<li>Fixed: remove imported brush guide shapes when converting to curves an expanded brush.</li>
<li>Fixed: hovering over starting node should be indicated in the pen tool.</li>
<li>Fixed: get default color calibration profile from the system on Windows.</li>
<li>Fixed: file overwrite notice on Windows when extension is not specified.</li>
<li>Fixed: show different cursors in stroke width tool for spine and width adjustments.</li>
<li>Fixed: use PDF 1.6 version when copying to pasteboard for older CS compatibility.</li>
<li>Fixed: allow tracing adjustment of 1 percent in preferences.</li>
<li>Fixed: resizing text with negative tracking.</li>
<li>Fixed: using both angle and direction constrain in node editor.</li>
<li>Fixed: option (Editing Options / Adjust Node Removal Curvature) to skip curvature approximation when deleting a node.</li>
<li>Fixed: use blue highlight in UI to indicate checked buttons.</li>
<li>Fixed: transform pivot should stay fixed when rotating.</li>
<li>Fixed: allow groups in divide and merge operations.</li>
<li>Fixed: artboard count was not selected when creating new documents.</li>
<li>Fixed: scaling selected nodes should also scale related control nodes correctly.</li>
<li>Fixed: set the first control point towards the next node when creating new shapes in the Pen tool.</li>
<li>Fixed: moving the end of a line with smooth node at the other end should update the curve.</li>
<li>Fixed: undoing some merge operations resulted in wrong positions.</li>
<li>Fixed: disable automatic vertical roman characters.</li>
<li>Fixed: skip empty objects in intersection operations.</li>
<li>Fixed: swap icon in color panels should be next to the color target knob.</li>
<li>Fixed: docking directly from horizontal margin to vertical was not working.</li>
<li>Fixed: transform each should consider individual object pivots.</li>
<li>Fixed: editing envelope shapes copied from other objects was broken.</li>
<li>Fixed: track isolation context changes in undo and redo.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/811/update-1-0-048</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:28:19 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/811.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Sep 2021 16:58:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.0.048 on Fri, 10 Sep 2021 17:25:46 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/3930">update 1.0.048</a>:</p>
<blockquote>
<p dir="auto">Improved: activate lasso tool by holding Option (Alt) key.</p>
</blockquote>
<p dir="auto">Yes! this is awesome!<br />
Honestly, just going through the list and seeing the additions and fixes to so many things we collectively spoke about; I'm testing them out - this is a really impressive update!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3933</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3933</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Fri, 10 Sep 2021 17:25:46 GMT</pubDate></item></channel></rss>
