<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 147]]></title><description><![CDATA[<h3>VectorStyler beta 147 release notes</h3>
<li>Improved: added distance (gap) snapping mode.</li>
<li>Improved: added distance indicators when snapping to objects or object distances.</li>
<li>Improved: improved performance when interactively changing objects (moving, scaling, and others).</li>
<li>Improved: performance improvements for panning, zooming and rotating views.</li>
<li>Improved: additional performance improvements for panning, zooming and rotating views.</li>
<li>Improved: performance of rendering stroke outline styles.</li>
<li>Improved: copy all decimals when copying text from number fields.</li>
<li>Improved: enabled real time preview of slider values in number fields.</li>
<li>Improved: added a restart button to preferences change notification.</li>
<li>Fixed: stroke width in scaled point text should not be stretched.</li>
<li>Fixed: closing path ends should result in a cusp node.</li>
<li>Fixed: stroke width on AI imported text.</li>
<li>Fixed: dismissing arrow popup in stroke popup should keep the stroke popup open.</li>
<li>Fixed: stroke alignment on closed shapes should not depend on the path direction.</li>
<li>Fixed: copy and paste text in file save dialog.</li>
<li>Fixed: keeping correct object hierarchy when importing some SVG files.</li>
<li>Fixed: various crashes in the user interface.</li>
<li>Fixed: purge history button in history panel.</li>
<li>Fixed: undo and redo for multiple copies resulting from transform repetitions.</li>
<li>Fixed: crash when selecting brush styles without an open document.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/82/build-147</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:56:14 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/82.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Jun 2020 19:04:59 GMT</pubDate><ttl>60</ttl></channel></rss>
