<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.052]]></title><description><![CDATA[<h3>VectorStyler 1.0.052 release notes</h3>
<li>Improved: angle snapping in polygon drawing to consider polygon specific angles.</li>
<li>Fixed: problem in stroke offset for some complex shapes.</li>
<li>Fixed: option for transparent preview in Offset Path, using 3 state preview check box.</li>
<li>Fixed: lasso selection tool indicator style.</li>
<li>Fixed: gap between context panel, toolbox and document tabs.</li>
<li>Fixed: drag and drop changes inside recorded actions.</li>
<li>Fixed: show missing glyphs in text.</li>
<li>Fixed: delete key should delete last drawn line while still in the line tool.</li>
<li>Fixed: do not show object outline for hidden (but still selected) objects.</li>
<li>Fixed: update save button state immediately after saving.</li>
<li>Fixed: Preferences to use most recent document units.</li>
<li>Fixed: selecting nodes when control points are too close to the node.</li>
<li>Fixed: text on path inside a group should transform correctly.</li>
<li>Fixed: selection highlight issues at very large zoom, outlines are not matching the document image.</li>
<li>Fixed: click tolerance issues at very large zooms.</li>
<li>Fixed: scrolling in context panel with track pad also scrolls number fields, block number field scrolling in context panel.</li>
<li>Fixed: some context panel buttons did not show the shortcut for the action in their tool tips.</li>
<li>Fixed: opening multiple files could lead to a deadlock.</li>
<li>Fixed: adjustment effect export to PDF and SVG files.</li>
<li>Fixed: printing adjustment effects.</li>
<li>Fixed: hovering state of some buttons did not update correctly (in Alignment panel, and toolbox).</li>
<li>Fixed: problems with displaying COLR OpenType color fonts.</li>
<li>Fixed: allow angle constraint larger than 45 degrees in preferences.</li>
<li>Fixed: rotating inside container should not move the pivot point.</li>
<li>Fixed: duplicating objects after move and skew should keep the pivot relative to the new object.</li>
<li>Fixed: crash when scrolling COLR fonts in the Glyph panel.</li>
<li>Fixed: file opening issues with containing imported graphics.</li>
<li>Fixed: corner on shape with stray nodes should skip the stray nodes.</li>
<li>Fixed: problems when pasting some AI content.</li>
<li>Fixed: select layer as active after changing its location in the Layers panel.</li>
<li>Fixed: creating new mesh gradient with the mesh tool resulted in multiple extra undo stores.</li>
<li>Fixed: scaling previously scaled text frames with the Scale tool resulted in wrong text size.</li>
<li>Fixed: rename in Layers panel (and some other) lists by pressing the return key.</li>
<li>Fixed: option to automatically open backup files left after crashes.</li>
<li>Fixed: stray segment cleanup should also remove self overlapping edges.</li>
<li>Fixed: in isolation mode new layers should be added under the current layer.</li>
<li>Fixed: extra contour objects are created when pressing Return in the Contour panel.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/838/update-1-0-052</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:28:30 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/838.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Sep 2021 18:54:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.0.052 on Wed, 22 Sep 2021 15:55:31 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/4097">update 1.0.052</a>:</p>
<blockquote>
<p dir="auto">Fixed: option to automatically open backup files left after crashes.<br />
Many great updates in this build - I've run into this one specifically a few times and the auto option open backup files after a crash is a great improvement to VS.</p>
</blockquote>
]]></description><link>https://www.vectorstyler.com/forum/post/4125</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/4125</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 22 Sep 2021 15:55:31 GMT</pubDate></item></channel></rss>
