<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.053]]></title><description><![CDATA[<h3>VectorStyler 1.0.053 release notes</h3>
<li>Improved: merge to create separate objects for non-overlapping shapes with the same style.</li>
<li>Improved: Envelope shape direction can be set from effect options.</li>
<li>Improved: point snapping performance in complex documents.</li>
<li>Improved: copy gradient color by holding Option(Alt).</li>
<li>Improved: click on gradient slider should apply the gradient on the selected objects.</li>
<li>Improved: new action to separate a path into non-overlapping parts (Object - Shape - Separate Path).</li>
<li>Improved: option to default to even-odd winding fill rule mode for new objects.</li>
<li>Fixed: resource leak problems after some time of use on Windows.</li>
<li>Fixed: window name in Windows task manager.</li>
<li>Fixed: copy artboard and content between canvases in the Canvas&amp;Artboard panel.</li>
<li>Fixed: break apart did not flatten transformations correctly.</li>
<li>Fixed: convert to curves should keep object transform for stroke.</li>
<li>Fixed: expand stroke should consider object transform.</li>
<li>Fixed: convert to curves did not copy duplicate object references.</li>
<li>Fixed: merge issues with complex shapes.</li>
<li>Fixed: color glyphs in Glyph panel were not shown on Windows.</li>
<li>Fixed: cannot delete node in single segment shape.</li>
<li>Fixed: cannot place as last object inside a layer in Layers panel.</li>
<li>Fixed: cannot select last character in text on path.</li>
<li>Fixed: moving pivot of multiple selected objects.</li>
<li>Fixed: blend with no stroke at one end should use blend to zero width stroke.</li>
<li>Fixed: blend transparency of stroke when blending objects.</li>
<li>Fixed: cannot resize docked panels.</li>
<li>Fixed: problems when recording repeated actions (like dragging a slider).</li>
<li>Fixed: non uniform color slider in Image Trace panel.</li>
<li>Fixed: positioning of tab in paragraph text.</li>
<li>Fixed: drawing filled shapes should select the fill color target.</li>
<li>Fixed: do not open layer when duplicating in layers panel.</li>
<li>Fixed: halftone image effect results in wrong colors at some places.</li>
<li>Fixed: drawing with Pen tool should not adjust an initial control point.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/861/update-1-0-053</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/861.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Sep 2021 17:38:13 GMT</pubDate><ttl>60</ttl></channel></rss>
