<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.054]]></title><description><![CDATA[<h3>VectorStyler 1.0.054 release notes</h3>
<li>Fixed: collapsed panel should stay collapsed.</li>
<li>Fixed: drag the whole panel from empty regions of a tab.</li>
<li>Fixed: option to transform brush with content.</li>
<li>Fixed: split text did not function in some cases.</li>
<li>Fixed: convert to curve should not move inner object.</li>
<li>Fixed: opening layers in panel when duplicating with buttons.</li>
<li>Fixed: pencil stabilizer should work at current zoom level.</li>
<li>Fixed: label for Undo action was wrong when shown in customization lists.</li>
<li>Fixed: focus the Name field when the renaming object view opens.</li>
<li>Fixed: drawing inside transformed objects applies the wrong transform.</li>
<li>Fixed: appearance panel did not work with text selections.</li>
<li>Fixed: image filters on text shape objects should use common box.</li>
<li>Fixed: show actual style of halftone effect, and default to point mode.</li>
<li>Fixed: problems with creating custom toolboxes.</li>
<li>Fixed: could not add root action in toolbox customization.</li>
<li>Fixed: redo button remains inactive in the context panel.</li>
<li>Fixed: hidden guide shapes should not be drawn.</li>
<li>Fixed: exclude and cut out path operation with grid shapes.</li>
<li>Fixed: glyph popup did not show glyphs on Windows.</li>
<li>Fixed: fill option for Offset Path.</li>
<li>Fixed: pattern brush presets should detach.</li>
<li>Fixed: text on path with bending should allow editing and highlight.</li>
<li>Fixed: show transformed member objects correctly when editing the bend effect.</li>
<li>Fixed: deleting unused effects may cancel others.</li>
<li>Fixed: stroke rendering at small width.</li>
<li>Fixed: importing PDF with spot colors can have unexpected results.</li>
<li>Fixed: converting group hierarchies with shape effects to curves should convert all.</li>
<li>Fixed: moving with the modal view may remove existing transformations from the selected objects.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/896/update-1-0-054</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:11 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/896.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Oct 2021 06:44:45 GMT</pubDate><ttl>60</ttl></channel></rss>
