<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 154]]></title><description><![CDATA[<h3>VectorStyler beta 154 release notes</h3>
<li>Fixed: use the name from document setup as a the default document name.</li>
<li>Fixed: use document name as the default file name for export.</li>
<li>Fixed: improve unit change when editing in number fields.</li>
<li>Fixed: duplication offset to use last duplication move only.</li>
<li>Fixed: possible crash when removing text in imported AI files.</li>
<li>Fixed: transform panel popup width was too small.</li>
<li>Fixed: popup panel sizes are persistent now.</li>
<li>Fixed: show brush content selection in context panel when brush tool is active.</li>
<li>Fixed: font style ordering with exotic style names.</li>
<li>Fixed: limit hairline width to pixel size in display options (Precision section).</li>
<li>Fixed: use solid fill for default object style.</li>
<li>Fixed: add "None" option to the stroke width list, to remove stroke style.</li>
<li>Fixed: add remove fill and stroke buttons next to the style drop downs buttons in the Properties panel.</li>
<li>Fixed: some images sizes can be wrong when importing multiple images from AI files.</li>
<li>Fixed: rendering image distortion effects while dragging objects.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/94/build-154</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:50:35 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/94.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Jul 2020 12:51:36 GMT</pubDate><ttl>60</ttl></channel></rss>
